[GRASS-dev] [GRASS GIS] #3055: Revise monochromatic color tables
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Display | Version: unspecified
Keywords: r.colors, d.rast, blues, greens, | CPU: Unspecified
  oranges, reds, sepia, water |
Platform: Unspecified |
The monochromatic color tables namely `blues`, `greens`, `oranges` and
`reds` added in r64283 start with white. It is probably obvious that it is
good that there is no black but I think that they also should not contain
white.
Using r.mapcalc, r.colors, and r.colors.matplotlib (`g.extension
r.colors.matplotlib`), you can try how the Matplotlib `Blues`, `Greens`,
`Oranges` and `Reds` look like.
color=blues
map=m_$color
g.region cols=500 rows=300 n=-300 s=-600 w=0 e=500
r.mapcalc "$map = col() / 10 + 2 * cos(col() * 100)"
r.colors map=$map color=$color
color=Blues
map=m2_$color
g.region cols=500 rows=300 n=-600 s=-900 w=0 e=500
r.colors.matplotlib map=$map color=$color
Also Moritz mentioned off-list that ''a quick look at Color Brewer shows
that they use values such as:''
255:255:229 for greens
255:247:236 for reds
You can notice that besides different start color Matplotlib uses also
different end color. Our color versions end e.g. with 0:0:255 (called
`blue` in GRASS) which is an arbitrary color based on its special position
in the RGB model not on its optical or aesthetic features. For the
technical part, the `greens` and `blues` does not show the waves on the
right and in comparison with the Matplotlib versions it seems to me that
even `reds` and `oranges` show less waves on the right.
I'm not sure how many color steps are needed for the Matplotlib colors. I
used 6 but perhaps just 2 (start and end) are enough.
The `sepia` color table from r33163 actually starts with white, `0:0:0`,
and ends with (almost) black, `255:254:251`, (or the other way around when
you don't use `-n`), so that's not good I think. I'm usually not able to
use it because of the black color. The gray scale image and the waves are
good (these two look like good indicators, see #3043). So, I would just
remove the stretch the current colors unless there is some good sepia
color table source.
The `sepia` color table from r68464 (from r.lake) doesn't show a big
gradient in gray scale (which might be good thing sometimes, but not now).
However, there is some and I don't know how to change it while preserving
other features especially the look which I think is really good here.
Note that changing these would be more serious change in behavior because
your result is changed even if you explicitly specify what you want (which
is not the case for change of default in #3043 where you just trust the
default which is changed for your good).
Note also that a monochromatic color tables are candidacies for new
default color table (#3043).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055&gt;
Resolution: | Keywords: r.colors, d.rast, blues, greens,
       CPU: | oranges, reds, sepia, water
  Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* Attachment "mono_current_grey_mpl_grey.png" added.
Current color tables (grey, blues, greens, oranges, reds, sepia, water) -
in grey scale - Matplotlib versions of Blues through Reds - in grey scale
Ticket URL: <http://trac.osgeo.org/grass/ticket/3055&gt;
Comment (by wenzeslaus):
[[Image(mono_current_grey_mpl_grey.png)]]
In column:
* grey
* blues
* greens
* oranges
* reds
* sepia
* water
In row: current state - current state in grey scale - b. g. o. r. from
Matplotlib - again in grey scale
Raster:
r.mapcalc "map = col() / 10 + 2 * cos(col() * 100)"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055#comment:1&gt;
In [changeset:"68755" 68755]:
#!CommitTicketReference repository="" revision="68755"
add GRASS green color table by Vincent Bain (see #3043 and #3055)
Ticket URL: </ticket/3055#comment:2>
In [changeset:"68907" 68907]:
#!CommitTicketReference repository="" revision="68907"
add GRASS green color table by Vincent Bain (see #3043 and #3055, backport
r68755)
Ticket URL: </ticket/3055#comment:3>
* Attachment "monochromatic_to_matplotlib.diff" added.
Patch to change monochromatic/monochrome color tables from r64283 (#2557)
to Matplotlib ones
Comment (by mlennert):
I don't have any strong feelings about my original ones (which were just
quick hacks). I find that for some the contrast seems to stronger in my
versions (blues for example), but I don't think we can find any one color
scheme that would satisfy everyone for every usage. And I agree that not
having white as the starting color is a good idea.
So, please go ahead and commit.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055#comment:4&gt;
  Priority: blocker | Milestone: 8.0.0
* priority: normal => blocker
* milestone: 7.2.4 => 8.0.0
Comment:
As mentioned in the original description, it is a change of behavior, so
it should wait for version 8 (and must be deiced before the release, so
blocker).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055#comment:10&gt;
Comment (by SBL):
Would be nice if custom color tables could be picked up from one or more
user-defined directories that is refered to e.g. in an environment
variable (lets say GRASS_CUSTOM_COLORS) That way, anyone can add
institutioal or personal color tables, independent from the GRASS
installation...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055#comment:11&gt;
Replying to [comment:11 SBL]:
installation...
Makes sense, but please, create a separate ticket for this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055#comment:12&gt;
Replying to [comment:10 wenzeslaus]:
blocker).
Personally, I'm not sure that we need to be this strict with color tables
which are only about visualization. I would say that targeting 7.6 as
milestone would be acceptable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3055#comment:13&gt;
