#3057: Problems with Numpy and matplotlib after updating through OSGeo4W
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.6
Component: Python | Version: svn-releasebranch72
Resolution: | Keywords: wingrass
CPU: Unspecified | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:18 hellik]:
> there must be a difference between the ''python stuff of the standalone-
winGRASS-build environment'' and the ''OSGeo4W-provided python stuff''!!
added the listed content of the both python27 folders (standalone and
OSGeo4W); some differences, but not yet any obvious.
> I'm getting closer now to the issue:
> next steps:
> - copy env.bat and grass72svn.bat from the ''C:\Program Files\GRASS GIS
7.2.svn\'' installation to a folder, e.g. D:\temp\testgrasspython
> - in D:\temp\testgrasspython\grass72svn.bat, ''set GISBASE=C:\Program
Files\GRASS GIS 7.2.svn'' points to the standalone installation
> - change in D:\temp\testgrasspython\env.bat that the python stuff points
to the OSGeo4W-python:
> set GRASS_PYTHON=C:\OSGeo4W64\bin\python.exe
> set PYTHONHOME=C:\OSGeo4W64\apps\Python27
> and now you get in the standalone installation (while pointing to the
OSGeo4W-python stuff) the same numpy error in startup like in the OSGeo4W-
winGRASS.
now tested it the other way around:
taking the OSGeo4W-winGRASS-installation; regarding python let's point to
the python stuff living in ''C:\Program Files\GRASS GIS 7.3.svn'' and
start OSGeo4W-winGRASS-7.3.svn
=> with pointing to the standalone installer python, also OSGeo4W-
winGRASS-7.3.svn starts '''without''' any numpy problem nor any problem
with raster profiling, bivariate scatterplots etc.
> conclusion:
yes confirmed, there is definitely some issue with OSgeo4W's python stuff.
tested on 3 different winboxes (7,8,10) with a fresh OSGeo4W installation.
Replying to [comment:21 annakrat]:
> Replying to [comment:20 sbl]:
> > It appears also on Ubuntu! So, I don`t think it is a Windows only
thing...
> I think I found the problem, will fix it today or tomorrow.
