[GRASS-dev] [GRASS GIS] #3059: r.external.out does not write CRS information
Reporter: sbl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Keywords: r.external.out | CPU: Unspecified
Platform: Unspecified |
At least for GeoTiffs, which is the format I used, files created with
r.external.out do not contain any CRS information.
The CRS is a central piece of information for a spatial data set and
should not get lost during export.
In order to reproduce try:
g.proj -g
r.external.out directory=tmp extension=.tif format=GTiff
options="COMPRESS=LZW,PREDICTOR=2"
r.mapcalc expression="test=1"
gdalinfo $GISDBASE/$LOCATION/$MAPSET/tmp/test.tif | grep -A 5 "Coordinate
System"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059&gt;
Resolution: | Keywords: r.external.out
Comment (by sbl):
Some additional observations:
A colleague and me are facing significant "interoperability problems" with
GeoTiffs produced with r.external.out, which (after FTP transfer) could
not be opened in ENVI.
ENVI complains about broken corner coordinates and a corrupted LZW-table.
The files are solar radiation grids (all integer) and are saved as Int32
by r.external.out.
They were results from a tiled processing which was merged using r.patch.
When I export via r.out.gdal I get a warning message that Metadata exceeds
32000 bytes and cannot be written to GeoTiff, and therefore will be
transferred to PAM. So this is possibly related to #3056
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:1&gt;
  Priority: major | Milestone: 7.0.5
Component: Raster | Version: 7.0.4
Changes (by neteler):
* priority: normal => major
* component: Default => Raster
Comment:
I can reproduce it with the NC location:
# NC Location
g.region raster=elevation -p
g.proj -w
PROJCS["Lambert Conformal Conic",
     GEOGCS["grs80",
         DATUM["North_American_Datum_1983",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Lambert_Conformal_Conic_2SP"],
     PARAMETER["standard_parallel_1",36.16666666666666],
     PARAMETER["standard_parallel_2",34.33333333333334],
     PARAMETER["latitude_of_origin",33.75],
     PARAMETER["central_meridian",-79],
     PARAMETER["false_easting",609601.22],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
mkdir -p $HOME/tmp
r.external.out directory=$HOME/tmp extension=.tif format=GTiff
r.mapcalc expression="test = 1"
gdalinfo $HOME/tmp/test.tif
Driver: GTiff/GeoTIFF
Files: test.tif
Size is 1500, 1350
Coordinate System is `'
Origin = (630000.000000000000000,228500.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Image Structure Metadata:
   COMPRESSION=LZW
   INTERLEAVE=BAND
Corner Coordinates:
Apparently some GDAL part is not initialized completely. I see in
https://trac.osgeo.org/grass/browser/grass/trunk/lib/raster/gdal.c#L431
that the use of GPJ_grass_to_wkt() is commented. Maybe that part needs to
be updated/completed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:2&gt;
Comment (by glynn):
Replying to [comment:2 neteler]:
to be updated/completed?
The main problem is that gproj depends upon libgis, which means that
libgis cannot depend upon gproj. However, it may be possible to load gproj
dynamically, in the same manner as GDAL. The only other option is to merge
gproj into libgis, making GDAL (along with its large and open-ended set of
dependencies) a hard dependency of libgis.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:3&gt;
Comment (by neteler):
Replying to [comment:3 glynn]:
Rather than merging libproj into libgis, your suggestion of dynamical
loading of libproj sounds more viable to avoid a dependency "hell".
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:4&gt;
  Priority: major | Milestone: 7.0.6
Comment (by sbl):
See also: #3191 and #3193
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:6&gt;
Since we run again into this problem, is there a way to "attach" the CRS?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:7&gt;
Comment (by mmetz):
Replying to [comment:7 neteler]:
CRS?
Yes, there is no dependency hell any more because library raster fns are
now (as of GRASS 7) in a separate library which can nowbe dependent on
libproj.
Please try trunk r72098 and relbr74 r72099.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:8&gt;
      Type: defect | Status: closed
  Priority: major | Milestone: 7.4.0
Resolution: fixed | Keywords: r.external.out
Changes (by sbl):
* status: new => closed
* resolution: => fixed
* milestone: 7.0.6 => 7.4.0
Comment:
Thanks Markus! I can confirm that projection information now is written to
GeoTiffs produced with r.external.out in GRASS 7.4.
However, like in r.out.gdal EPSG codes of the projections are not written
here either (see #3048).
Even for Locations purely created from EPSG code. Would be really helpful
if EPSG codes somehow could be added where appropriate (and recorded in
the projection information in GRASS).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:9&gt;
  Priority: major | Milestone: 7.4.1
Changes (by mmetz):
* milestone: 7.4.0 => 7.4.1
Comment:
adjust milestone
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:10&gt;
