[GRASS-dev] [GRASS GIS] #3060: Create location from command line using "r.in.gdal" and similar
Reporter: mankoff | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Startup | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
I find that I am continually creating some new dummy location just so I
can then create the actual location I want using {{{r.in.gdal}}}. I could
maintain a global dummy location and use that, but it makes the code less
portable when I share it with others. Therefore, I often do this:
rm -fR grass
mkdir grass
grass70 -c EPSG:4326 ./grass/latlon
r.in.gdal -c input=/path/to/somefile.TIF location=foo output=tmp
exit
grass70 ./grass/foo/PERMANENT
I find it difficult to know what EPSG code I should use for somefile.TIF,
because it reports many (see below), therefore it would be nice to create
the location from outside of GRASS, but using GRASS. For example,
{{{grass70 -c input=/path/to/somefile importer=r.in.gdal}}}
Coordinate System is:
PROJCS["WGS 84 / UTM zone 33N",
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
             SPHEROID["WGS 84",6378137,298.257223563,
                 AUTHORITY["EPSG","7030"]],
             AUTHORITY["EPSG","6326"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AUTHORITY["EPSG","4326"]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",15],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AXIS["Easting",EAST],
     AXIS["Northing",NORTH],
     AUTHORITY["EPSG","32633"]]
Origin = (444892.500000000000000,8690407.500000000000000)
Pixel Size = (15.000000000000000,-15.000000000000000)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3060&gt;
Already possible. See: https://grass.osgeo.org/grass70/manuals/grass7.html
________________________________________
Von: grass-dev [grass-dev-bounces@lists.osgeo.org] im Auftrag von GRASS GIS [trac@osgeo.org]
Gesendet: Freitag, 10. Juni 2016 19:40
Betreff: [GRASS-dev] [GRASS GIS] #3060: Create location from command line using "r.in.gdal" and similar
rm -fR grass
mkdir grass
exit
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
     UNIT["metre",1,
grass-dev mailing list
grass-dev@lists.osgeo.org
      Type: enhancement | Status: closed
Resolution: worksforme | Keywords:
Changes (by sbl):
* status: new => closed
* resolution: => worksforme
Comment:
See: http://grass.osgeo.org/grass70/manuals/grass7.html
There is[[BR]]
grass70 -c geofile
Ticket URL: <https://trac.osgeo.org/grass/ticket/3060#comment:1&gt;
