[GRASS-dev] [GRASS GIS] #3062: Segmentation fault with r.buffer
Reporter: escheper | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Raster | Version: 7.0.4
Keywords: buffer | CPU: Other
Platform: Linux |
I'm trying to buffer raster regions at various resolutions. The following
commands went well:
g.region w=-180.0 s=-90.0 e=180.0 n=90.0 res=0.00833333
r.buffer input=rasset output=rasbuf distances=10.0 units="kilometers" --o
The next commands give a segmentation fault at "Finding buffer zones..."
(at around 37%).
g.region w=-180.0 s=-90.0 e=180.0 n=90.0 res=0.002777777
I'm using Ubuntu 16.04 LTS on an Intel Xeon E5-1650 server with >64GB
memory.
Does anyone have a workaround or an idea what the cause is?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062&gt;
Resolution: | Keywords: buffer
       CPU: Other | Platform: Linux
Comment (by neteler):
Please make the map "rasset" available (via r.pack) or tell us how to
generate it in order to enable us to reproduce the problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:1&gt;
Changes (by escheper):
* Attachment "settlements.pack" added.
packed input raster
Comment (by escheper):
Added the file settlements.pack which is a small version of the original
input raster.
The size of the original raster is 16MB which cannot be added as an
attachment. I could send this file by WeTransfer or is there another way?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:2&gt;
Did some futher tests. Using the small version did not resulted in a
segmentation fault. So the original raster is needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:3&gt;
The original file can be downloaded
[http://www.gistools.nl/grass/settlements2.pack here].
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:4&gt;
Resolution: | Keywords: r.buffer
Changes (by martinl):
* keywords: buffer => r.buffer
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:5&gt;
CMD='r.buffer input=r120749038 output=rasbuf distances=10.0
units=kilometers --o'
valgrind --tool=memcheck --leak-check=yes --show-reachable=yes $CMD --o
==11148== Memcheck, a memory error detector
==11148==
==11148== 933,120,000 bytes in 1 blocks are still reachable in loss record
73 of 73
==11148== at 0x4C2AB80: malloc (in /usr/lib/valgrind
/vgpreload_memcheck-amd64-linux.so)
==11148== by 0x5076A4A: G__malloc (alloc.c:39)
==11148== by 0x40333B: read_input_map (read_map.c:39)
==11148== by 0x402814: main (main.c:141)
There is no G_free(map) it seems:
raster/r.buffer $ grep 'alloc\|free' *.c | grep -v GNU
parse_dist.c: distances = (struct Distance *)G_calloc(count,
sizeof(struct Distance));
read_map.c: map = (MAPTYPE *) G_malloc((size_t) window.rows *
window.cols * sizeof(MAPTYPE));
read_map.c: cell = Rast_allocate_c_buf();
read_map.c: G_free(cell);
support.c: Rast_free_cats(&pcats);
write_map.c: cell = Rast_allocate_c_buf();
write_map.c: G_free(cell);
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:6&gt;
Thanks for your support!
Reading the map didn't cause the problem. The method read_input_map()
finishes without a fault.
The segmentation fault occurs in execute_distance() in execute.c after the
message "Finding buffer zones..." is shown.
After adding "G_free(map);" in read_input_map() the r.buffer command
crashes within that method and execute_distances() isn't executed. So I
removed the "G_free(map)" again.
After adding some debug statements I have noticed the program crashes at
the following point in process_left().
         /* convert 1,2,3,4 to -1,0,1,2 etc. 0 becomes ndist */
         G_message(_("PL6"));
         G_message(_("cur_zone: %i ZONE_INCR: %i ndist: %i to_ptr:
%i"),cur_zone,ZONE_INCR,ndist,to_ptr);
         if ((cur_zone = *--to_ptr))
             cur_zone -= ZONE_INCR;
         else
             cur_zone = ndist;
The last lines of the debug output was:
PL6
cur_zone: 16538 ZONE_INCR: 2 ndist: 1 to_ptr: -2116621104
Segmentation fault
I do not have much experience with C so maybe you can give me a clue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:7&gt;
Replying to [comment:7 escheper]:
> else
> cur_zone = ndist;
Good analysis, this number looks like an integer overflow to me (it is
negative). A C expert wanted here...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:8&gt;
Changed the %i to %u. Now the numbers/pointers are positive.
Also changed
to
         if ((cur_zone == *--to_ptr))
but still get the segmentation fault :(.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:9&gt;
Comment (by annakrat):
I would say it is related to the fact that `to_ptr` is unsigned char, so
it can overflow fast, although I don't understand the algorithm there.
Note the comment in the code:
/* if MAPTYPE is changed to unsigned short, MAX_DIST can be set to 2^16-2
  * (if short is 2 bytes)
So I would try to change it to unsigned short. Unfortunately I can't
easily test the testcase, I have little memory right now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:10&gt;
Replying to [comment:10 annakrat]:
2^16-2
Thanks to your tip I found the solution.
Changing the MAPTYPE didn't solve the problem. But the problem was another
overflow.
I'm using a 64,800 x 129,600 grid which results in 8,398,080,000 cells (or
bytes). This is far beyond the maxint (2,147,483,647) and causes the
overflow.
After changing most int variables in the r.buffer code in long types the
segmentation fault disappeared :).
I didn't check the output visually, that's what I need to do next. Having
no segmentation fault is very promising.
Except from changing the integer types to long, I have changed some "=" to
"==" in "if" statements in process_left.c, process_at.c and
process_rite.c. This didn't solve the segmentation fault but in my opinion
the original code seems not to be correct.
I found some other lines that may not be correct too. But I'm not sure
about it. These lines are:
process_rite.c(90): *to_ptr = (first_zone = i) + ZONE_INCR;
process_row.c(34): for (r = row; r >= 0 && (first_zone =
find_distances(r)) >= 0; r--)
process_row.c(47): r < window.rows && (first_zone = find_distances(r)) >=
0; r++) {
read_map.c(65): if ((*ptr++ = (*cell++ != 0))) {
read_map.c(81): if ((*ptr++ = !Rast_is_c_null_value(cell++))) {
Can anyone confirm this?
Remains the following questions:
- How are other GRASS modules dealing with large grids? Do they have the
same problem?
- What will be the impact on the output raster after changing some "=" to
"=="? Do we get other result buffers?
- In what way should I do a "pull request" of my changes in de code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3062#comment:11&gt;
Replying to [comment:11 escheper]:
same problem?
to "=="? Do we get different result buffers?
> - In what way should I do a "pull request" of my changes in de code?
[https://trac.osgeo.org/grass/wiki/HowToSVN#LocalDiffs Create a diff] and
attach it here. You can make it simpler for us if you first identify the
exact source of the error and then upload the patch which fixes without
any extra changes. Changing int variables to long int might result in
spending too much memory, so you shouldn't change it unless you consider
the consequences.
If you think there are other changes which need to be done to run r.buffer
correctly, please explain them. For example, it's not clear why "=="
should replace "=" and where. And yes, very probably we get then different
results.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:12&gt;
Comment (by mmetz):
Replying to [comment:6 neteler]:
> ==11148==
record 73 of 73
A segfault is reflected in valgrind as "invalid read of size ..." or
"invalid write of size ...". Still reachable blocks are not a cause for
segfault.
> [...] I found the solution.
another overflow.
(or bytes). This is far beyond the maxint (2,147,483,647) and causes the
overflow.
Having no segmentation fault is very promising.
Note that long is a signed 32 bit integer except for POSIX 64 bit systems.
On Windows, long is always 32 bit and would not solve the problem. Better
use long long, or even better, ask for a platform-independent 64 bit
integer type in GRASS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:13&gt;
Comment (by martinl):
Is this really blocker for the release?
Ticket URL: <http://trac.osgeo.org/grass/ticket/3062#comment:14&gt;
  Priority: major | Milestone: 7.0.5
Changes (by annakrat):
* priority: blocker => major
Comment:
No, it seems to be only problem with huge data.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:15&gt;
  Priority: major | Milestone: 7.6.2
* milestone: 7.0.7 => 7.6.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3062#comment:18&gt;
