GDAL
June 13, 2016, 11:08am
1
#3063: In grass 7.3, no shared object files libgrass_vector and libgrass_raster
7.1
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.3.0
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
When staring up GRASS (v 7.3, r68671) I am getting the following error /
warnings:
GRASS 7.3.svn (Data_latlon):~ > ERROR 1: libgrass_vector.7.1.svn.so:
cannot open shared object file: No such file or directory
ERROR 1: libgrass_vector.7.1.svn.so: cannot open shared object file: No
ERROR 1: libgrass_raster.7.1.svn.so: cannot open shared object file: No
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
June 13, 2016, 12:25pm
2
7.1
Resolution: | Keywords:
Comment (by neteler):
Replying to [ticket:3063 pvanbosgeo]:
warnings:
You have version confusion on your system.
If you compiled yourself, you need to redo that after a
make distclean
Ticket URL: <http://trac.osgeo.org/grass/ticket/3063#comment:1> ;
GDAL
June 13, 2016, 12:29pm
3
7.1
Comment (by pvanbosgeo):
Strange, I did a complete clean compilation, or so I thought. Will try
again, perhaps some files did not get removed properly.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:2> ;
GDAL
June 13, 2016, 1:01pm
4
7.1
I must be missing something obvious here, but this is what I do:
Remove my previous install
sudo rm -r /usr/local/grass7
rm -r .grass7
Completely new checkout
cd /home/paulo/Software/spatial/
svn checkout https://svn.osgeo.org/grass/grass/trunk grass7
Compile and run
cd grass7
./configure --prefix=/usr/local/grass7 --enable-64bit
make -j4
sudo make install
/usr/local/grass7/bin/grass73
Same result / warning as above
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:3> ;
GDAL
June 13, 2016, 4:10pm
5
7.1
Replying to [comment:3 pvanbosgeo]:
BTW: please add which operating system you are using.
ok, but we shure that the files are really gone.
No need to do that.
make distclean
is enough. To be double, sure run also next to find remaining garbage:
svn status --no-ignore
> Compile and run
ok, now, within the session, run
which g.region
ldd `which g.region | grep grass`
in order to see where g.region is and which libraries it loads from where.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:4> ;
GDAL
June 13, 2016, 5:35pm
6
7.1
Sorry, my system is Linux Ubuntu 14.04 (x64). I did make sure the previous
install is completely removed.
Running which g.region gives me
/usr/local/grass7/grass-7.3.svn/bin/g.region
Running ldd `which g.region | grep grass` gives me
linux-vdso.so.1 => (0x00007ffee6137000)
libgrass_gproj.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_gproj.7.3.svn.so
(0x00007f6a781a9000)
libgrass_vector.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_vector.7.3.svn.so
(0x00007f6a77f35000)
libgrass_g3d.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_g3d.7.3.svn.so
(0x00007f6a77d14000)
libgrass_raster.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_raster.7.3.svn.so
(0x00007f6a77ae9000)
libgrass_gis.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_gis.7.3.svn.so
(0x00007f6a778a7000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f6a775a1000)
libproj.so.0 => /usr/lib/libproj.so.0 (0x00007f6a7734f000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f6a76f8a000)
libgdal.so.20 => /usr/local/gdal/lib/libgdal.so.20 (0x00007f6a75e9d000)
libgrass_dbmiclient.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_dbmiclient.7.3.svn.so
(0x00007f6a75c92000)
libgrass_dbmibase.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_dbmibase.7.3.svn.so
(0x00007f6a75a80000)
libgrass_dgl.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_dgl.7.3.svn.so
(0x00007f6a75867000)
libgrass_dig2.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_dig2.7.3.svn.so
(0x00007f6a7564e000)
libgrass_linkm.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_linkm.7.3.svn.so
(0x00007f6a7544b000)
libgrass_rtree.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_rtree.7.3.svn.so
(0x00007f6a75241000)
libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007f6a7501d000)
libgrass_btree2.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_btree2.7.3.svn.so
(0x00007f6a74e17000)
libpq.so.5 => /usr/lib/libpq.so.5 (0x00007f6a74be8000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f6a749e4000)
libgrass_datetime.7.3.svn.so =>
/usr/local/grass7/grass-7.3.svn/lib/libgrass_datetime.7.3.svn.so
(0x00007f6a747db000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f6a745c2000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
(0x00007f6a743a4000)
/lib64/ld-linux-x86-64.so.2 (0x00007f6a783b2000)
libfreexl.so.1 => /usr/local/lib/libfreexl.so.1 (0x00007f6a7419a000)
libodbc.so.1 => /usr/lib/x86_64-linux-gnu/libodbc.so.1
(0x00007f6a73f33000)
libodbcinst.so.1 => /usr/lib/x86_64-linux-gnu/libodbcinst.so.1
(0x00007f6a73d21000)
libkmldom.so.0 => /usr/lib/x86_64-linux-gnu/libkmldom.so.0
(0x00007f6a73a78000)
libkmlbase.so.0 => /usr/lib/x86_64-linux-gnu/libkmlbase.so.0
(0x00007f6a73862000)
libkmlengine.so.0 => /usr/lib/x86_64-linux-gnu/libkmlengine.so.0
(0x00007f6a7362e000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f6a73404000)
libjasper.so.1 => /usr/lib/x86_64-linux-gnu/libjasper.so.1
(0x00007f6a731ad000)
libnetcdf.so.7 => /usr/lib/libnetcdf.so.7 (0x00007f6a72e70000)
libhdf5.so.7 => /usr/lib/x86_64-linux-gnu/libhdf5.so.7
(0x00007f6a729d4000)
libmfhdf.so.0 => /usr/lib/libmfhdf.so.0 (0x00007f6a72798000)
libdf.so.0 => /usr/lib/libdf.so.0 (0x00007f6a7249b000)
libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0x00007f6a7227a000)
libspatialite.so.5 => /usr/lib/x86_64-linux-gnu/libspatialite.so.5
(0x00007f6a71c7e000)
libsqlite3.so.0 => /usr/lib/x86_64-linux-gnu/libsqlite3.so.0
(0x00007f6a719c5000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f6a71787000)
libcurl-gnutls.so.4 => /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so.4
(0x00007f6a71525000)
libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2
(0x00007f6a711be000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
(0x00007f6a70eba000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f6a70ca4000)
libgeos-3.4.2.so => /usr/lib/libgeos-3.4.2.so (0x00007f6a70920000)
libssl.so.1.0.0 => /lib/x86_64-linux-gnu/libssl.so.1.0.0
(0x00007f6a706c1000)
libcrypto.so.1.0.0 => /lib/x86_64-linux-gnu/libcrypto.so.1.0.0
(0x00007f6a702e5000)
libkrb5.so.3 => /usr/lib/x86_64-linux-gnu/libkrb5.so.3
(0x00007f6a7001a000)
libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2
(0x00007f6a6fe16000)
libgssapi_krb5.so.2 => /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2
(0x00007f6a6fbcf000)
libldap_r-2.4.so.2 => /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2
(0x00007f6a6f97e000)
libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7
(0x00007f6a6f774000)
liburiparser.so.1 => /usr/lib/liburiparser.so.1 (0x00007f6a6f55a000)
libminizip.so.0 => /usr/lib/x86_64-linux-gnu/libminizip.so.0
(0x00007f6a6f352000)
libjpeg.so.8 => /usr/lib/x86_64-linux-gnu/libjpeg.so.8
(0x00007f6a6f0fd000)
libhdf5_hl.so.7 => /usr/lib/x86_64-linux-gnu/libhdf5_hl.so.7
(0x00007f6a6eecd000)
libidn.so.11 => /usr/lib/x86_64-linux-gnu/libidn.so.11
(0x00007f6a6ec9a000)
librtmp.so.0 => /usr/lib/x86_64-linux-gnu/librtmp.so.0
(0x00007f6a6ea80000)
libgcrypt.so.11 => /lib/x86_64-linux-gnu/libgcrypt.so.11
(0x00007f6a6e800000)
libgnutls.so.26 => /usr/lib/x86_64-linux-gnu/libgnutls.so.26
(0x00007f6a6e542000)
liblber-2.4.so.2 => /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2
(0x00007f6a6e333000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f6a6e111000)
libk5crypto.so.3 => /usr/lib/x86_64-linux-gnu/libk5crypto.so.3
(0x00007f6a6dee2000)
libkrb5support.so.0 => /usr/lib/x86_64-linux-gnu/libkrb5support.so.0
(0x00007f6a6dcd7000)
libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1
(0x00007f6a6dad3000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2
(0x00007f6a6d8b8000)
libsasl2.so.2 => /usr/lib/x86_64-linux-gnu/libsasl2.so.2
(0x00007f6a6d69d000)
libgssapi.so.3 => /usr/lib/x86_64-linux-gnu/libgssapi.so.3
(0x00007f6a6d45f000)
libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0
(0x00007f6a6d25a000)
libtasn1.so.6 => /usr/lib/x86_64-linux-gnu/libtasn1.so.6
(0x00007f6a6d046000)
libp11-kit.so.0 => /usr/lib/x86_64-linux-gnu/libp11-kit.so.0
(0x00007f6a6ce04000)
libheimntlm.so.0 => /usr/lib/x86_64-linux-gnu/libheimntlm.so.0
(0x00007f6a6cbfb000)
libkrb5.so.26 => /usr/lib/x86_64-linux-gnu/libkrb5.so.26
(0x00007f6a6c973000)
libasn1.so.8 => /usr/lib/x86_64-linux-gnu/libasn1.so.8
(0x00007f6a6c6d2000)
libhcrypto.so.4 => /usr/lib/x86_64-linux-gnu/libhcrypto.so.4
(0x00007f6a6c49f000)
libroken.so.18 => /usr/lib/x86_64-linux-gnu/libroken.so.18
(0x00007f6a6c28a000)
libffi.so.6 => /usr/lib/x86_64-linux-gnu/libffi.so.6 (0x00007f6a6c082000)
libwind.so.0 => /usr/lib/x86_64-linux-gnu/libwind.so.0
(0x00007f6a6be59000)
libheimbase.so.1 => /usr/lib/x86_64-linux-gnu/libheimbase.so.1
(0x00007f6a6bc4b000)
libhx509.so.5 => /usr/lib/x86_64-linux-gnu/libhx509.so.5
(0x00007f6a6ba02000)
libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007f6a6b7c9000)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:5> ;
GDAL
June 13, 2016, 5:51pm
7
7.1
I see:
all good now? `g.region -p` works?
Ticket URL: <http://trac.osgeo.org/grass/ticket/3063#comment:6> ;
GDAL
June 13, 2016, 6:19pm
8
7.1
Yes, g.region -p seems to work. What is still there at startup is those
Not sure if it has any other effect, tried a few functions which seem to
work fine. Anything specific that shouldn't work with those errors which I
could test?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:7> ;
GDAL
June 13, 2016, 6:24pm
9
7.1
Got it.. You need to rebuild all addons.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:8> ;
GDAL
June 13, 2016, 8:45pm
10
7.1
Thanks for the suggestion. Unfortunately it doesn't seem to help. Rebuild
all, start grass again, with same error messages. Puzzling
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:9> ;
GDAL
June 13, 2016, 8:49pm
11
7.1
Then try
strace grass73
No need to post it but it will show you at some point what seeks for it.
However, indeed GRASS works, right?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:10> ;
GDAL
June 13, 2016, 9:14pm
12
7.1
Checking all output created at start up of grass for any line with 7.1 in
it, but nothing.
But yes, it seems to work all right based on the limited testing I did, so
I guess I can just ignore it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:11> ;
GDAL
September 16, 2017, 4:55pm
13
7.1
Priority: normal | Milestone: 7.4.0
pvanbosgeo, is this still an issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:13> ;
GDAL
November 12, 2017, 12:07pm
14
7.1
Type: defect | Status: closed
Resolution: worksforme | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => worksforme
Comment:
No answer, closing
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:14> ;
