#3074: v.in.ogr / v.overlay: ERROR due to non-SQL-compliant layer names
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Vector | Version: unspecified
Keywords: v.in.ogr,v.overlay | CPU: Unspecified
Platform: Unspecified |
When importing e.g. a shape file, e.g. myshape-v01.shp, v.in.ogr assigns
the layer name "myshape-v01" to the resulting GRASS vector map.
When this map is used later in e.g. v.overlay (not sure about other
modules) the layer name is used as part / suffix of the table name and the
"CREATE TABLE" command fails, because the "-" in the name is not allowed.
v.overlay produces the new vector map, but without attribute table...
Could be probably tackled tother with: #2765
Yet, I am not sure if this is an issue with v.overlay or with v.in.ogr...
