[GRASS-dev] [GRASS GIS] #3078: ps.map unicode support
Reporter: kuszinger | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.0
Component: Ps.map | Version: 7.0.4
Keywords: codepage, utf-8 | CPU: All
Platform: Unspecified |
ps.map currently handles latin1 (iso8859-1) codepage texts in all manners.
Regarding the international use of GRASS GIS it would be essential to
widen this option to support UTF-8 encoded strings for text, labelling and
so on.
Extract from present ps.map manual:
"For users wanting to use special characters (such as accented characters)
'''it is important to note that ps.map uses ISO-8859-1 encoding'''. This
means that your instructions file will have to be encoded in this
encoding. If you normally work in a different encoding environment (such
as UTF-8), you have to transform your file to the ISO-8859-1 encoding, for
example by using the iconv utility:
iconv -f UTF-8 -t ISO_8859-1 utf_file > iso_file
Ticket URL: <https://trac.osgeo.org/grass/ticket/3078&gt;
      Type: enhancement | Status: closed
Resolution: duplicate | Keywords: codepage, utf-8
       CPU: All | Platform: Unspecified
Changes (by annakrat):
* status: new => closed
* resolution: => duplicate
Comment:
Seems duplicate of #1349.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3078#comment:1&gt;
