#3085: Batch import with import raster data tool does not recognize projection
information
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
Importing using the Import raster data (menu: file - import raster data -
common formats import) works as advertised when importing a file. However,
when trying to import a batch of rasters in a directory, the
'reprojection' screen is shown, with the message that 'projection of
following layers do not match with projection of current location
(followed by a list of all layers in that directory).
I have had this issue with layers from various data sets, including last
data from the Africlim
(https://grasswiki.osgeo.org/wiki/Global_datasets#Africlim_maps) data set,
which are latlon (wgs84) layers with identical coordinate system header
(using gdalinfo).
To reproduce this, one can export the raster layers from the NC sample
data set, and then import them all in once using the import raster data
tool.
information
Resolution: | Keywords:
Comment (by mlennert):
What exactly is the issue, here ?
I get the exact same window be it with one file or with a directory. It is
just an additional step to make you conscious about the fact that the
module will proceed with reprojecting the files. Just select the files you
are sure you want to import with reprojection and then proceed.
projection
information
Sorry, my description might not have been clear. The Africlim data I refer
to above are in latlon, which I tried to import in a latlon location.
Importing one layer proceeds without problem (i.e., without the projection
window). Only when I try to import multiple layers using the directory
option I am presented with that projection window. But why reprojecting if
the projection of the layers matches that of the location (as evident from
the fact that one layer imports without need for reprojection).
In the example with the NC sample data set, I am exporting layers from the
location and importing them in the same location. This means the layers
should just import, without reprojection. When importing one layer (using
the file option) that is exactly what happens, the layer is imported. Like
above, only when importing multiple layers using the directory option, the
reprojection window is shown. Again, I see no reason why the layers should
be reprojected. The projection already matches that of the location
(obviously).
