db.droptable -f table=roads_copy
Forcing ...
File "C:\Program Files\GRASS GIS
7.0.4/scripts/db.droptable.py", line 99, in <module>
main()
7.0.4/scripts/db.droptable.py", line 77, in main
used = grass.db.db_table_in_vector(table)
7.0.4\etc\python\grass\script\db.py", line 193, in
db_table_in_vector
for f in vector_db(vect, stderr=nuldev).itervalues():
7.0.4\etc\python\grass\script\vector.py", line 43, in
vector_db
**args)
7.0.4\etc\python\grass\script\core.py", line 446, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
7.0.4\etc\python\grass\script\core.py", line 313, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['v.db.connect', '--q', '-g', 'map=pippopluto@user1',
'sep=;'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
* status: new => closed
* resolution: => worksforme
Comment:
Replying to [comment:3 neteler]:
> I have tried this on Linux:
> grass73 ~/grassdata/nc_spm_08_grass7/user1/
> g.copy vector=roadsmajor,roads_copy
> ... works ok on Linux.
> Can another user with MS-Windows please test (also with 7.04)?
Works just fine with 7.2.0 and 7.3. Reopen only if a failing example is
provided.
