[GRASS-dev] [GRASS GIS] #3090: d.font does not change default font in monitors
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Display | Version: unspecified
Keywords: d.font | CPU: x86-64
Platform: Linux |
d.font -l and d.fontlist give 439 possibilities for fonts. However,
d.font font="whatever_font_from_the_439_items_list"
does not change font setting in monitors, nor raise any error/warning. The
only error appears when trying to set, for example, {{{font=romanp}}}
which is indeed listed as option in d.font manual page
(https://grass.osgeo.org/grass73/manuals/d.font.html).
Whatever font I choose, monitors keep using default roman, which IMHO
looks awful and makes that the output of d.text or d.vect.thematic, for
example, look terrible, too.
The only way I found to effectively change font for d.mon was with:
export GRASS_FONT="sans"
I use fedora 23, grass trunk r68780.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3090&gt;
Resolution: | Keywords: d.font
       CPU: x86-64 | Platform: Linux
Comment (by annakrat):
d.font calls `D_font` but that affects only the font in that process.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3090#comment:1&gt;
Comment (by veroandreo):
Replying to [comment:1 annakrat]:
If by process you mean a particular monitor, that's the case I'm
reporting. Here, what I do:
d.mon wx0
d.font font="sans"
d.text "Hello GRASS GIS"
No sans font, but the default roman. However, please try saving the wx0
monitor with "Save Display to file", something strange happens... The
"Hello GRASS" part disappears and only "GIS" word remain and with a
different font.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3090#comment:2&gt;
Comment (by neteler):
Probably caused by reason which leads to #3137
Ticket URL: <https://trac.osgeo.org/grass/ticket/3090#comment:3&gt;
  Priority: normal | Milestone: 7.8.0
Changes (by veroandreo):
* milestone: 7.2.4 => 7.8.0
Comment:
I still get the same behavior in freshly compiled trunk
Ticket URL: <https://trac.osgeo.org/grass/ticket/3090#comment:9&gt;
