[GRASS-dev] [GRASS GIS] #3094: wxGUI: error when profiling a raster map
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: wxGUI | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: MSWindows 8 |
when starting to profile a raster map in the wxGUI
   File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\ma
pdisp\frame.py", line 1139, in OnProfile
self.Profile(rasters=rasters)
pdisp\frame.py", line 1147, in Profile
controller=self.profileController)
   File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\wx
plot\profile.py", line 54, in __init__
BasePlotFrame.__init__(self, parent=parent, size=size,
**kwargs)
plot\base.py", line 107, in __init__
self.client = plot.PlotCanvas(self)
NameError
global name 'plot' is not defined
tested with
System Info
GRASS Version: 7.3.svn
GRASS SVN revision: r68875
Build date: 2016-07-07
Build platform: x86_64-w64-mingw32
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
       CPU: x86-64 | Platform: MSWindows 8
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Should be fixed in 7.0.5svn.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:1&gt;
      Type: defect | Status: reopened
Resolution: | Keywords:
Changes (by hellik):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:1 martinl]:
reopen the ticket see #3204#comment:3
tested there by
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r69793
Build date: 2016-11-10
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:2&gt;
Comment (by hellik):
now tested with
System Info
GRASS version: 7.0.5
GRASS SVN Revision: 69636
Build Date: 2016-10-02
Build Platform: x86_64-w64-mingw32
GDAL/OGR: 2.1.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
   File "C:\OSGEO4~1\apps\grass\grass-7.0.5\gui\wxpython\mapd
isp\frame.py", line 1044, in OnProfile
isp\frame.py", line 1052, in Profile
   File "C:\OSGEO4~1\apps\grass\grass-7.0.5\gui\wxpython\wxpl
ot\profile.py", line 56, in __init__
**kwargs)
ot\base.py", line 92, in __init__
NameError
also in the 7.0.x-line still an issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:3&gt;
Replying to [comment:3 hellik]:
> now tested with
> System Info
> GDAL/OGR: 2.1.1
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.14.1
> Python: 2.7.5
> wxPython: 2.8.12.1
> **kwargs)
> NameError
see ​https://trac.osgeo.org/grass/ticket/3057#comment:18
standalone GRASS GIS 7.2.svn works without any problems; trying it with
the setup in #3057#comment:18 (standalone winGRASS pointing to the
OSGeo4W-python stuff), then I get the same error as reported above.
conclusion: the numpy startup issue (#3057) and this failing are
interconnected!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:4&gt;
  Priority: normal | Milestone: 7.2.0
Changes (by annakrat):
* milestone: 7.0.5 => 7.2.0
Comment:
Fixed in r69797 in trunk, please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:5&gt;
Replying to [comment:5 annakrat]:
tested by
System Info
GRASS SVN revision: r69797
Build date: 2016-11-13
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
fix confirmed.
backport needed (?):
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:6&gt;
* status: reopened => closed
Comment:
Backported to 72 and 70.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:7&gt;
