#3097: r.in.aster does not work
Reporter: venkat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Keywords: | CPU: Unspecified
Platform: MSWindows 8 |
Running r.in.aster with Aster hdf file
gives me the error shown below.
Also, the currently available Aster data
in HDF format [1] contains on 14bands (band3b
not included). However, r.in.aster is coded
to read 15 band file.
Importing into GRASS ...
File "C:\Program Files (x86)\GRASS GIS
7.0.0/scripts/r.in.aster.py", line 166, in <module>
main()
7.0.0/scripts/r.in.aster.py", line 127, in main
import_aster(proj, srcfile, tempfile, band)
7.0.0/scripts/r.in.aster.py", line 158, in import_aster
outfile = "%s.%s" % (output, band)
NameError: global name 'output' is not defined
100 - done.
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.6
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: MSWindows 8
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"69859" 69859]:
#!CommitTicketReference repository="" revision="69859"
r.in.aster: pass output prefix to import function (fixes #3097: r.in.aster
does not work)
Comment (by mlennert):
Could you please test if the version in trunk works for you ?
It fixes the 'output' name error. Concerning the issue with the absent
band 3b, I haven't changed anything as this does not keep the module from
functioning and importing the bands. It just output a message such as:
ERROR 4:
HDF4_EOS:EOS_SWATH:AST_L1T_00306252000142255_20150409233900_101837.hdf:VNIR_Swath:ImageData3B:
No such file or directory
Which I find clear enough. But we could change the code to test for the
existence of the file before trying to import and emitting a warning. Just
not high on my priority list as the module as is works as expected.
Replying to [comment:4 mlennert]:
> In [changeset:"69933" 69933]:
> #!CommitTicketReference repository="" revision="69933"
> r.in.aster: r.in.aster: pass output prefix to import function (fixes #3097, merge from trunk r69859)
I got no feedback, but as the module will not function at all (AFAICT)
without this fix, and the fix is non-invasive on the rest of GRASS, I
applied it to g72 and g70.
