#31: NVIZ in GRASS6.2.3 (some problems)
Reporter: clerici | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.2.3
Keywords: |
1) In the control panel the LOOK cancel button does not work (it works on
6.0)
2) In the control panel the LOOK RESET button does not reset twist (bug?)
3) In the Surface panel the masking doesn't have any effect on 'fine'
surfaces but only on 'wire' surfaces and vectors maps.
4) In the Surface panel the emission parameter (in Surface Attribute)
seems ineffective.
5) In the Surface panel the Transparency function has a strange behaviour
with the 'constant' elevation surfaces. When a transparency value is
assigned to the surface and the DRAW button is pressed, the surface is
hidden by the other surfaces. Only by pressing the Draw Current button in
the Surface panel the transparency is effective, but reduces progressively
each time the button is pressed. If the DRAW button is pressed again the
surface return to be hidden. For a check the elevation.dem and a surface
at an elevation of 5,000 m can be used.
6) In the panel Vectors Lines/3D Polygons the Display Flat function seems
ineffective.
7) The Vector points are not displayed on the surface, but seem suspended
in the air above the surface, reproducing the surface morphology (the
elevation difference seems to be a constant). Only if the surface is a
plane at constant elevation the points are located on the surface (checked
with archsites and bugsites on elevation.dem and on a surface at 5000 m).
The problem doesn't exist in grass6.0.
Greetings
Ticket URL: <http://trac.osgeo.org/grass/ticket/31>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
