#3100: v.vol.rst WARNING in GRASS 7 still says cellout and cellinp rasters
Reporter: rorschach | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Keywords: | CPU: x86-64
Platform: Linux |
A very minor issue. GRASS 7 changed the names of cellinp and cellout
parameters of the v.vol.rst module to cross_input and cross_output
respectively but when the module issues a warning it still says:
WARNING: Unable to create '''cellout''' raster map without '''cellinp'''
(''emphasis supplied'')
This may be minor but I think it throws off a user because there is no
cellout or cellinp option anymore in GRASS 7.
I haven't checked if the same goes for other WARNING/ERROR messages for
other modules. The main source code probably needs a little proofreading
to avoid simple ''defects'' like this. I would volunteer but I don't have
access to the main svn (yet).
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by hellik):
Replying to [ticket:3100 rorschach]:
you can have a look online at the code of trunk and all the branches here:
Comment (by wenzeslaus):
Thanks. A better fix is using the names as defined in the `Option`
structure by attribute `key` (example from
[source:grass/trunk/raster/r.slope.aspect/main.c#L315 r.slope.aspect]:
#!c
G_fatal_error(_("%s=%s - must be a positive number"), parm.zfactor->key,
parm.zfactor->answer);
Can you please also check if there are other places like this, e.g. using
`grep cell` and create a patch using `svn diff`?
so the message will pop up if either of them is missing or if both are
missing, so this is not very helpful. Especially when you don't give
either of them, you get:
ATTENTION: Unable to create <(null)> raster map without cross_input raster
map being specified
I think this should be handled by parameter dependency rules for the
parser, and not by the code. Something like:
Priority: normal | Milestone: 7.0.6
Comment (by mlennert):
Replying to [comment:6 mlennert]:
> Replying to [comment:4 neteler]:
> > Attempt done in r69439: if ok to be backported
> Actually, the test tests for the existance of both maps:
> if ((cellinp != NULL) && (cellout != NULL)) {
raster
> map being specified
> G_option_collective(parm.cellinp, parm.cellout)
Try the attached patch which implements the above and other checks that
were done in the code.
