GDAL
July 14, 2016, 7:14pm
1
#3101: v.in.pdal compilation issue
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Vector | Version: unspecified
Keywords: v.in.pdal | CPU: x86-64
Platform: Linux |
Compilation of `v.in.pdal` fails on my computer with
main.cpp:62:47: error: ‘pdal::Dimension: :Enum’ has not been declared
pdal::Dimension: :Enum dim_to_use_as_z)
main.cpp: In function ‘void pdal_point_to_grass(Map_info*, line_pnts*,
line_cats*, pdal::PointViewPtr, pdal::PointId, GLidarLayers*, int, int)’:
main.cpp:67:38: error: ‘Id’ is not a namespace-name
using namespace pdal::Dimension::Id;
I have self-compiled pdal
pdal-config --version
1.2.0
g++ --version
g++ (Debian 5.4.0-6) 5.4.0 20160609
Ticket URL: <https://trac.osgeo.org/grass/ticket/3101> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
2
Component: Compiling | Version: unspecified
Resolution: | Keywords: v.in.pdal
CPU: x86-64 | Platform: Linux
Changes (by martinl):
* component: Vector => Compiling
Ticket URL: <http://trac.osgeo.org/grass/ticket/3101#comment:1> ;
GDAL
July 14, 2016, 10:18pm
3
Comment (by wenzeslaus):
There might be more. PDAL did several releases since I wrote `v.in.pdal`
and I didn't have time to update.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3101#comment:2> ;
GDAL
May 19, 2017, 10:35pm
4
Priority: normal | Milestone: 7.2.2
Changes (by ptschrum):
* cc: ptschrum (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3101#comment:5> ;
GDAL
March 12, 2018, 8:51pm
5
Priority: normal | Milestone: 7.2.3
Comment (by neteler):
See r72253: v.in.pdal: change API calls to PDAL 1.6.0 (available in G7.4).
See also #3243
Ticket URL: <https://trac.osgeo.org/grass/ticket/3101#comment:7> ;
GDAL
March 12, 2018, 11:38pm
6
Reporter: martinl | Owner: wenzeslaus
Changes (by wenzeslaus):
* owner: grass-dev@… => wenzeslaus
Comment:
Assigning to myself for clarity, but should be fixed in r72253 from #3496
by felixg for 7.4. Do we need/want to backport?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3101#comment:8> ;
GDAL
March 13, 2018, 1:55pm
7
In [changeset:"72363" 72363]:
#!CommitTicketReference repository="" revision="72363"
v.in.pdal: change API calls to PDAL 1.6.0, see #3496 , #3243 , #3101 , #2732
(author: felixg, backport of trunk r72246) + GPL header added in r72245
Ticket URL: <https://trac.osgeo.org/grass/ticket/3101#comment:9> ;
GDAL
September 24, 2018, 2:50am
8
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.4
Resolution: fixed | Keywords: v.in.pdal, PDAL
* status: new => closed
* keywords: v.in.pdal => v.in.pdal, PDAL
* resolution: => fixed
Comment:
Error related to changes in PDAL API. Fixed in r72246, backported to 7.4
in r72253. backported to 7.2 in r72363. Closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3101#comment:12> ;
