[GRASS-dev] [GRASS GIS] #3102: v.to.db compactness and fractal dimension
Reporter: mmetz | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.3.0
Component: Vector | Version: 7.0.1
Keywords: v.to.db,shape metrics | CPU: All
Platform: All |
If several areas share the same category, v.to.db sums up area sizes and
perimeters for all areas with the same category, but for compactness and
fractal dimension, the values of the last area processed are used.
Instead, for compactness and fractal dimension, area size and perimeter
length should be summed up for each category and at the end compactness
and fractal dimension should be calculated from the area size and
perimeter length sums for each category value.
Further on, compactness aka shape index is normalized to the area size of
the most compact shape (a circle), but fractal dimension is not. This
normalization is also done by e.g. FRAGSTATS.
The formula for compactness is
perimeter / (2.0 * sqrt(M_PI * area))
which is for given area size and perimeter length of an object the area
size of a cirlce with the same perimeter divided by the area size of the
object.
The formula for fractal dimension is
2.0 * log(perimeter) / log(area)
but should be
2.0 * log(perimeter / (2.0 * sqrt(M_PI)) / log(area)
which is for given area size and perimeter length of an object the log of
the area size of a cirlce with the same perimeter divided by the log of
the area size of the object.
Further on, there are problems with using the log() function because
log(1) is 0. That means that for area sizes smaller than 1, growing
towards 1, the result approaches -infinity and for areas larger than 1 and
growing further, the result decreases from +infinity. Thus for area sizes
equal 1, the result is undefined, it could be + or -infinity. Results can
also be negative or positive, depending on whether perimeter and/or area
size are < 1. These problems could be avoided by using log(1 + x) instead
of log(x).
The fractal dimension is not only dependent of the shape (cirlce, square,
star etc) but also on the size, e.g. larger squares have a smaller fractal
dimension than smaller squares. This should be added to the manual to
facilitate interpretation of the fractal dimension.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3102&gt;
  Priority: normal | Milestone: 7.4.0
Resolution: | Keywords: v.to.db,shape metrics
       CPU: All | Platform: All
Comment (by mlennert):
See also #3419.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3102#comment:2&gt;
  Priority: normal | Milestone: 7.4.1
Comment (by martinl):
What is status of this issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3102#comment:4&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.4.2
Resolution: fixed | Keywords: v.to.db,shape metrics
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"72866" 72866]:
#!CommitTicketReference repository="" revision="72866"
v.to.db: fix compactness and fractal dimension (fixes #3102)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3102#comment:6&gt;
      Type: defect | Status: reopened
Changes (by neteler):
* status: closed => reopened
* resolution: fixed =>
Comment:
(reopening the automatic closing, since milestone = 7.4.x)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3102#comment:7&gt;
Changes (by mmetz):
* status: reopened => closed
Comment:
In [changeset:"72869" 72869]:
#!CommitTicketReference repository="" revision="72869"
v.to.db: fix compactness and fractal dimension (fixes #3102, backport
trunk r72866,8)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3102#comment:8&gt;
