[GRASS-dev] [GRASS GIS] #3105: r.stats.zonal parameter description
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
In the manual page of r.stats.zonal, one has to give a base raster map and
a cover raster map. From these terms alone it may not be clear which map
should be what without going to the (linked) r.statistics manual page. I
would like to suggest to:
1) copy the relevant parts to the description on the r.stats.zonal manual
page.
2) describe the parameter base as "Name of base/zonal/category raster
map". At minimum, use the word 'zonal' (it is part of the name of the
function for a reason)
Point 2 applies to the description of the 'base' parameter of r.statistics
as well.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3105&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"69101" 69101]:
#!CommitTicketReference repository="" revision="69101"
r.statistics + r.stats.quantile + r.stats.zonal manual: extended (partial
fix #3105)
Ticket URL: </ticket/3105#comment:1>
Component: Docs | Version: unspecified
Resolution: fixed | Keywords: r.stats.zonal
* keywords: => r.stats.zonal
* component: Default => Docs
Comment:
Backported as well. Feel free to reopen (ideally with text suggestions) if
not satisfied.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3105#comment:2&gt;
