#3108: db selection: integer overflow
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Database | Version: svn-trunk
Keywords: v.db.univar db.select overflow | CPU: Unspecified
Platform: Unspecified |
I don't have the time to look into it right now, but there seems to be
some serious overflow happening in vector db selection:
v.info -c communes
INTEGER|REVENU_FIS
Directly in sqlite I get the following:
sqlite> select min(REVENU_FIS), max(REVENU_FIS), sum(REVENU_FIS) from
communes;
0|7558043447|857584291001
However, using GRASS tools, I get:
db.select sql="select min(REVENU_FIS), max(REVENU_FIS), sum(REVENU_FIS)
from communes"
min(REVENU_FIS)|max(REVENU_FIS)|sum(REVENU_FIS)
0|-1031891145|-1409168199
and
v.db.univar communes col=REVENU_FIS
Reading column values...
Number of values: 36610
Minimum: -2001804970
Maximum: 2098650536
Range: 4100455506
Mean: 20726578.6176728
Arithmetic mean of absolute values: 21930820.0978148
Variance: 7.76208158145393e+15
Standard deviation: 88102676.3580649
Coefficient of variation: 4.25071006571934
Sum: 758800043193
Ticket URL: <https://trac.osgeo.org/grass/ticket/3108>
