#3112: wxgui scatterplot tool: C++ assertion "m_window" failed at
../src/gtk/dcclient.cpp(2043) in DoGetSize(): GetSize() doesn't work
without window
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: wxGUI | Version: svn-trunk
Keywords: scatterplot | CPU: Unspecified
Platform: Unspecified |
Trying to use the bivariate scatterplot tool in the Map Display I get the
following error and nothing else:
File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-
linux-gnu/gui/wxpython/mapdisp/frame.py", line 1175, in
OnScatterplot
win = ScatterFrame(parent=self, rasterList=raster)
File
linux-gnu/gui/wxpython/wxplot/scatter.py", line 42, in
__init__
BasePlotFrame.__init__(self, parent, size=size, **kwargs)
File
linux-gnu/gui/wxpython/wxplot/base.py", line 113, in
__init__
self.client.canvas.Bind(wx.EVT_LEFT_DOWN,
self.OnMouseLeftDown)
File "/usr/lib/python2.7/dist-
packages/wx-3.0-gtk2/wx/_core.py", line 4228, in Bind
event.Bind(self, id, id2, handler)
packages/wx-3.0-gtk2/wx/_core.py", line 4572, in Bind
target.Connect(id1, id2, et, function)
packages/wx-3.0-gtk2/wx/_core.py", line 4182, in Connect
return _core_.EvtHandler_Connect(*args, **kwargs)
wx._core
PyAssertionError
doesn't work without window
Maybe linked to wx 3 ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/3112>
