#3114: v.kriging: images in manual do not show (and when shown should be bigger)
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Addons | Version: unspecified
Keywords: v.kriging manual | CPU: Unspecified
Platform: Unspecified |
The v.kriging addon could do with a bit more love for documentation: In
the manual the images are not shown. All images as in an 'images'
directory within the addons directory, but that images directory does not
get installed together with the addon.
I don't know if there is Makefile magic to install that directory. The
other solution is to put all images into the root directory of the addon.
When doing the latter, the images appear in the manual page, but in the
version displayed within the wxGUI module window, these images are too
small (when displaying the html in a web browser, the size is smallish,
but acceptable).
Fig. 10 is not displayed because of a typo in the file name.
Finally, even though the examples are helpful, there should be more
information in the description, explaining each of the parameter's roles
and in which of the phases they are useful.
the manual the images are not shown. All images as in an ‘images’
I don’t know if there is Makefile magic to install that directory.
I have tried adding VPATH [1] to the Makefile. I would like to ask… does the issue with missing images happen just here [2] or does it appear in general? I have tried to install the modules from addons (after cleaning my GRASS) and the images seem to work correctly in my computer. I would like to understand the issue better, may I ask what is the difference between compiling module at user’s computer and here [2]?
The other solution is to put all images into the root directory of the addon.
I would prefer them to stay in separate subdirectories, but if it won’t work, I shall replace them.
but acceptable).
I have modified the layout, hopefully this helps.
Thanks to Markus for fixing it.
information in the description, explaining each of the parameter’s roles
Thank you for the suggestion, I will add the information immediately after fixing the images.
On Sun, Aug 28, 2016 at 11:08 PM, Eva Stopková <eva.stopkova@gmail.com> wrote:
Dear all,
This will not work and also not necessarily portable. And image
copying is already implemented and no private solution should be
implemented.
See
include/Make/HtmlRules.make
I would like to ask... does
Yes.
No
compiling module at user's computer and here [2]?
If the images are at root directory of the addon nothing has to be
done in the addon Makefile and it will work on any platform.
addon.
I would prefer them to stay in separate subdirectories, but if it won't
Why do you need a separate subdirectory (especially images/small/)?
Maybe a Makefile trick could be added to support a subdirectoy but two
of them are not ideal.
bigger)
Resolution: | Keywords: v.kriging manual
Changes (by neteler):
* cc: evas (added)
Comment:
At time all images are broken due to the recent r69293
I have edited the manual and no images are needed anymore. May I enclose
the case studies as a pdf file to the addon directory, until a paper on
v.kriging will be prepared?
should be bigger)
* cc: evas (added)
Comment:
I don't think anyone ever answered this: yes, you can put the PDF in the directory. It would be very nice if you could link to it in the man page, so that "normal" user can access it. This would mean using the direct link to trac.osgeo.org/grass/...
Thank you for the reminder; I prepared the pdf file with some case studies in 2016 [1] and I edited the manual, so no images are needed anymore. I’ve checked the link from the manual to the pdf recently, it does not work at the moment. In the next weeks, I am moving to another place, but after that I am ready to fix it. There are still several updates from 2018 [2] that I’ve done in v.kriging that should be tracked as well.
