#3115: v.kriging: segfault if a parameter is not set
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Addons | Version: unspecified
Keywords: v.kriging required parameter | CPU: Unspecified
segfault |
Platform: Unspecified |
In the v.kriging addon, when I only provide the parameters marked as
required (+ the -2 flag for 2D interpolation) I get the following:
v.extract elev_lid792_randpts out=elev_lid792_selected random=500 --o
v.kriging -2 input=elev_lid792_selected@user1 phase=initial icolumn=value
WARNING: Not recommended to process for sparse or spatially heterogeneous
data. The result can be inaccurate - trying to solve asap...
Reading coordinates...
Segmentation fault
I have to add the report parameter for it to work:
At this stage, two unasked-for files are in the same directory: dataE.dat
and
variogram_hz_tmp.txt.
Required parameters should be declared as such and not lead to a segfault.
And any temporary files created during the run of the module should be
erased at the end.
segfault |
Segmentation fault
I have fixed the bug like this: if the report name is missing, just initial
phase (preliminary experimental variogram computation) is performed and the
user is asked to repeat it with non-empty report parameter if he wish to
continue with theoretical variogram and interpolation.
and
erased at the end.
These temporary files are necessary, as they store settings and results
from previous phases to be available in current phase of interpolation. And
the process needs to be splitted into phases, because there is an
interaction with the user needed (theoretical parameters settings according
to experimental variogram). Unfortunatelly, this is not possible to manage
interactively during module performance.
As these files are unasked-for indeed, I have added the information about
them into command output: If initial phase is successfully accomplished,
the user is warned not to erase temporary files <dataE.dat> and
<variogram_hz_tmp.txt>. They are deleted in middle (final) phase
automatically, but in previous module version, the user had been informed
just in case that they were missing accidentally.
Priority: normal | Milestone: 7.0.6
Resolution: | Keywords: v.kriging required parameter
CPU: | segfault
Unspecified | Platform: Unspecified
Comment (by mlennert):
Response from Eva on the ML:
On 04/10/16 22:00, Eva Stopková wrote:
> 2016-08-04 15:42 GMT+02:00 GRASS GIS <trac@osgeo.org
> <mailto:trac@osgeo.org>>:
> grass-dev@…
7.0.5
> unspecified
> Unspecified
> segfault |
as
--o
> icolumn=value
> heterogeneous
asap...
> Segmentation fault
> icolumn=value
> report=report.txt
> initial phase (preliminary experimental variogram computation) is
> performed and the user is asked to repeat it with non-empty report
> parameter if he wish to continue with theoretical variogram and
> interpolation.
> dataE.dat
> and
> segfault.
be
> erased at the end.
> And the process needs to be splitted into phases, because there is an
> according to experimental variogram). Unfortunatelly, this is not
> possible to manage interactively during module performance.
> about them into command output: If initial phase is successfully
> accomplished, the user is warned not to erase temporary files
> <dataE.dat> and <variogram_hz_tmp.txt>. They are deleted in middle
> (final) phase automatically, but in previous module version, the user
> had been informed just in case that they were missing accidentally.
Changes are in r69676.
This sounds like a good solution. Thank you !
Another option would be to split the module into three modules. That way
for each phase you can clearly define the inputs and outputs. It might
make it clearer for the user. On the other hand, I understand the
reasoning behind one module for kriging...
IMHO, this really calls for a GUI wrapper above the module (or modules)
that makes the different calls, based on interactive input from the user.
Moritz
P.S. When responding to bug tickets, it is always better to do this within
the bug tracker, including a reference to the changeset in svn, so that
your responses are logged there.
