[GRASS-dev] [GRASS GIS] #3117: d.mon wx0: GtK issues
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: wxGUI | Version: svn-releasebranch72
Keywords: wx0, d.mon | CPU: Unspecified
Platform: Unspecified |
I get a lot of warnings after having updated my laptop to Fedora 24:
d.mon wx0
# startup: tons of these warnings
(main.py:6274): Gtk-CRITICAL **: gtk_box_gadget_distribute: assertion
'size >= 0' failed in GtkCheckButton
# window resize: tons of these warnings
(main.py:6274): Gtk-WARNING **: Allocating size to wxPizza 0x558b2ed9d9a0
without calling gtk_widget_get_preferred_width/height(). How does the code
know the size to allocate?
My system:
GDAL: 2.0.2
PROJ.4: 4.9.1
GEOS: 3.4.2
SQLite: 3.11.0
Python: 2.7.12
wxPython: 3.0.2.0
Platform: Linux-4.6.3-300.fc24.x86_64-x86_64-with-fedora-24-Twenty_Four
This clutters the terminal a lot. A fix would be appreciated.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117&gt;
Resolution: | Keywords: wx0, d.mon
Comment (by annakrat):
I found this:
https://bugzilla.redhat.com/show_bug.cgi?id=1323598
This is probably out of our scope.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:1&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: wx0, d.mon
Changes (by neteler):
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [comment:1 annakrat]:
> I found this:
Ok, I have opened a new "wxGTK3" ticket with Fedora:
https://bugzilla.redhat.com/show_bug.cgi?id=1364580
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:2&gt;
      Type: defect | Status: reopened
* status: closed => reopened
* resolution: wontfix =>
Comment:
The Fedora wxGTK3 maintainer needs to know how to run GDB on d.mon.
I checked the process table and found that eventually mapdisp/main.py is
run but I am not able to bring it up myself:
GRASS 7.3.svn (nc_spm_08_grass7):~ > python
$HOME/grass73/gui/wxpython/mapdisp/main.py
$HOME/grass73/gui/wxpython/mapdisp/main.py wx0
/home/neteler/grassdata/nc_spm_08_grass7/landsat/.tmp/oboe.localdomain/MONITORS/wx0
640 480 0
@package mapdisp.main
@brief Start Map Display as standalone application
Classes:
  - mapdisp::DMonMap
  - mapdisp::Layer
  - mapdisp::LayerList
  - mapdisp::DMonGrassInterface
  - mapdisp::DMonFrame
  - mapdisp::MapApp
Usage:
python mapdisp/main.py monitor-identifier /path/to/map/file
/path/to/command/file /path/to/env/file
GRASS 7.3.svn (nc_spm_08_grass7):~ > l
$HOME/grassdata/nc_spm_08_grass7/landsat/.tmp/oboe.localdomain/MONITORS/wx0
total 12
-rw-rw-r-- 1 neteler neteler 3571 Aug 6 09:27 render.py
-rw-rw-r-- 1 neteler neteler 0 Aug 6 09:27 cmd
-rw-rw-r-- 1 neteler neteler 5 Aug 6 09:27 pid
-rw-rw-r-- 1 neteler neteler 310 Aug 6 09:27 env
How to manually start wx0 from cmd line?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:3&gt;
This should work:
d.mon wx0
python `g.gisenv GISBASE`/gui/wxpython/mapdisp/main.py wx0 `g.gisenv
GISDBASE,LOCATION_NAME,MAPSET sep=/`/.tmp/$HOSTNAME/MONITORS/wx0 640 480 0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:4&gt;
Comment (by neteler):
Here the answer from the Fedora packager:
See https://bugzilla.redhat.com/show_bug.cgi?id=1364580
---------- Forwarded message ----------
Date: Sep 8, 2016 1:10 AM
Subject: [Bug 1364580] wxGTK3 warnings "flooding" the terminal
--- Comment #5 from Scott Talbert ---
(In reply to markusN from comment #0)
> At startup of a wx window (graphical output): tons of these warnings
appear:
'size
This error can be avoided by making the window wider, e.g.:
d.mon wx0 width=700
It is complaining that there isn't enough space for the checkbox.
I'm not sure yet about the wxPizza errors.
Looks like an error on our part (and the new wxGTK3 is more picky about
the size)?
Ticket URL: <http://trac.osgeo.org/grass/ticket/3117#comment:5&gt;
Replying to [comment:5 neteler]:
> --- Comment from Scott Talbert ---
'size
> d.mon wx0 width=700
I have set the width to 720 pixel in 7.0.svn 7.2.svn and trunk (r69485,
r69486, r69487).
Remains the wxPizza error...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:6&gt;
Replying to [comment:6 neteler]:
In the Fedora tracker I got notified that the new "wxGTK3-3.0.2-29" no
longer shows this "wxPizza" error. I'll make tests as soon as I get that
package.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:7&gt;
  Priority: normal | Milestone: 7.2.1
Replying to [ticket:3117 neteler]:
> d.mon wx0
Further analysis showed that this is a GTK and not a wxGTK error which
also appears elsewhere.
It seems to be this one:
https://bugzilla.gnome.org/show_bug.cgi?id=765700
https://github.com/GNOME/gtk/commit/ddcf47026dbbe58dca3b34c7bb1ec63bb50a861a
and here a workaround I found for meld:
https://bugzilla.gnome.org/attachment.cgi?id=335456&action=diff
Would a similar fix also help here (where to apply)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:9&gt;
  Priority: normal | Milestone: 7.2.4
Probably there is some hope (and it appears to be a GTK bug/non-feature:
https://bugzilla.redhat.com/show_bug.cgi?id=1411165
   --> https://bugzilla.redhat.com/show_bug.cgi?id=1488249
     --> https://bugzilla.gnome.org/show_bug.cgi?id=767136#c2
       --> 17 Mar 2018:
https://gitlab.gnome.org/GNOME/gtk/commit/eb01ba8573bec47e02c8fc4eaf10e2f7cff522dd
One day it will be released with a new GTK version :slight_smile:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:14&gt;
  Priority: normal | Milestone: 7.8.0
Component: wxGUI | Version: svn-trunk
* version: svn-releasebranch72 => svn-trunk
* milestone: 7.2.4 => 7.8.0
Comment:
The annoying terminal "spam" problem remains...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:15&gt;
Comment (by veroandreo):
Both in Fedora and Ubuntu...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:16&gt;
Comment (by mlennert):
Replying to [comment:16 veroandreo]:
+Debian proper.
The amount of clutter really depends on the the window size. In French
locale, I have to enlargen the Map Display, for example, for the warnings
to disappear. So, it seems that there is some issue with window sizes
apparently calibrated for a specific locale, or for specific screen
geometry.
Using a tiling windows manager makes it even worse for me as windows float
less, but are rather adapted to existing screen real estate.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:17&gt;
Replying to [comment:17 mlennert]:
> +Debian proper.
geometry.
float less, but are rather adapted to existing screen real estate.
This comment should actually have gone to #3348, although I think the two
are pretty much the same so could probably be merged.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3117#comment:18&gt;
