[GRASS-dev] [GRASS GIS] #3119: r.out., gdal -c should not write Metadata: COLOR_TABLE_RULE_RGB
#3119: r.out.,gdal -c should not write Metadata: COLOR_TABLE_RULE_RGB
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Keywords: r.out.gdal | CPU: Unspecified
Platform: Unspecified |
At time, when suppressing the color table export (eg when writing out in
GeoTIFF format) with
  r.out.gdal -c ...
still the metadata are written:
   Metadata:
     COLOR_TABLE_RULES_COUNT=5
     COLOR_TABLE_RULE_RGB_0=1.000000e+00 1.122440e+04 255 255 0 0 255 0
     COLOR_TABLE_RULE_RGB_1=1.122440e+04 2.244780e+04 0 255 0 0 255 255
     COLOR_TABLE_RULE_RGB_2=2.244780e+04 3.367120e+04 0 255 255 0 0 255
     COLOR_TABLE_RULE_RGB_3=3.367120e+04 4.489460e+04 0 0 255 255 0 255
     COLOR_TABLE_RULE_RGB_4=4.489460e+04 5.611800e+04 255 0 255 255 0 0
The code is here:
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.out.gdal/export_band.c#L315
Perhaps the if condition here should also consider
"suppress_main_colortable"?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3119&gt;
Resolution: | Keywords: r.out.gdal
Comment (by mmetz):
Replying to [ticket:3119 neteler]:
in GeoTIFF format) with
> r.out.gdal -c ...
> Metadata:
> The code is here:
The new 'm' flag suppresses writing out GRASS color rules to metadata in
order to enhance compatibility with other GIS software not using GDAL
(r69128-30 for trunk, relbr72, relbr70).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3119#comment:1&gt;
Comment (by neteler):
Thanks.
Just an idea: should -c trigger -m automatically or is there any -c use
case where the GRASS color rules are still wanted in the metadata?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3119#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 neteler]:
> Thanks.
The main purpose of -c is to suppress those long color tables for UInt16
in GTiff: one separate entry for each possible value which makes rendering
very slow. GTiff color tables and GRASS color rules are not the same, e.g.
a simple GRASS color rule such as
0 black
255 white
is expanded to 256 entries for Byte. GRASS r.in.gdal prefers GRASS color
rules as custom metadata over standard color tables, therefore these GRASS
color rules are wanted also with the -m flag. BTW, earlier versions of
QGIS also recognized these GRASS color rules. Format-dependent color
tables as such are not custom metadata, the GDAL driver decides if the
selected format supports color tables. Therefore I would regard the -c and
-m flags as independent of each other.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3119#comment:3&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.2.3
Resolution: fixed | Keywords: r.out.gdal
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
Closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3119#comment:7&gt;
