#3121: d.barscale and northarrow positioning problem when off-screen rendering
Reporter: kuszinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Display | Version: svn-trunk
Keywords: d.northarrow, d.barscale | CPU: Unspecified
Platform: Unspecified |
If GRASS rendering environment is set to work to file:
os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
os.environ['GRASS_RENDER_TRANSPARENT'] = 'TRUE'
os.environ['GRASS_RENDER_FILE_COMPRESSION'] = '0'
os.environ['GRASS_RENDER_FILE_MAPPED'] = 'TRUE'
os.environ['GRASS_RENDER_WIDTH'] = '3000'
os.environ['GRASS_RENDER_HEIGHT'] = '2000'
and rendering into a window on this area:
os.environ['GRASS_RENDER_FRAME'] = '248,1063,187,1567'
(or other sub-window)
barscale and especially northarrow displays at weird locations.
Grid rendering is OK and raster legend seems to behave ok (being at ~ same
percent as on screen)
It seems to be a ofset problem. There is a sample attached with several
images. Rendering commands are always the same. The only difference is
that if it happens to screen or file and in the second case
GRASS_RENDER_FRAME is smaller (= bigger margin).
barscale rendering:
d.barscale style="full_checker" at="44.3,10.3" label="m" bgcolor="none"
northarrow:
d.northarrow style="basic_compass" at="82.6,22.4" label="E"
color="139:105:20" fill_color="139:105:20"
It seems that northarrow and barscale rendered somehow without the "left
margin" so there could be a kind of ofset problem in the rendering area.
I do understand that northarrow and barscale positioning percentages are
for the whole screen ( = file in this case).
Also when reaching the edge of GRASS_RENDER_FRAME edge is reached by this
map gadgets, they are cut and not drawn outside this GRASS_RENDER_FRAME.
Positioning of raster legend should be compared to these modules to find
the difference.
Detected also 7.0.4, 7.2 and 7.3 weekly snapshot versions, 7.2 named in
ticket
Ticket URL: <https://trac.osgeo.org/grass/ticket/3121>
