[GRASS-dev] [GRASS GIS] #3130: r.out.gdal: add alpha channel support
Reporter: neteler | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-releasebranch72
Keywords: r.out.gdal | CPU: Unspecified
Platform: Unspecified |
At time the export of RGB data with nodata is rather difficult.
grass72 ~/grassdata/nc_spm_08_grass7/landsat
# test case:
# set region to be half off the NC Landsat scene:
g.region n=226831.5 s=221188.5 w=626430 e=634467 res=28.5 -p
d.mon wx0
d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
# yes, null is expected:
r.univar lsat7_2000_30 -g | grep null
null_cells=24750
r.out.gdal lsat7_2000 output=lsat7_2000_RGB.tif --o
Checking GDAL data type and nodata value...
  100%
Using GDAL data type <Byte>
Input raster map contains cells with NULL-value (no-data). The value 0
will
be used to represent no-data values in the input map. You can specify a
nodata value with the nodata option.
  100%
But in this case the 0 value is a data value and should not be used for
nodata. The only solution seems to be an extra alpha channel to be stored
in the resulting GDAL file (here: GeoTIFF).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130&gt;
Resolution: | Keywords: r.out.gdal
Comment (by mmetz):
Replying to [ticket:3130 neteler]:
> # test case:
> d.mon wx0
> null_cells=24750
> 100%
will
> 100%
nodata.
According to Landsat metadat, 0 is not a valid data value, valid range is
1 - 255. Also, r.info -r shows that 0 is not present, therefore 0 can be
used for nodata.
> The only solution seems to be an extra alpha channel to be stored in the
You mean r.out.gdal should create this extra alpha channel internally? You
could also try the PHOTOMETRIC and ALPHA creation options for GeoTIFF with
a corresponding alpha channel created manually.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:1&gt;
Comment (by neteler):
Replying to [comment:1 mmetz]:
is 1 - 255. Also, r.info -r shows that 0 is not present, therefore 0 can
be used for nodata.
Well, this was just intended as simple example to reproduce the issue.
Indeed I am using different data. At least there is no guarantee that 0 is
never a valid dataset while having 8 bit to be exported.
Yes, I thought so.
> You could also try the PHOTOMETRIC and ALPHA creation options for
GeoTIFF with a corresponding alpha channel created manually.
Interesting - do you have an example? Would be happy to close this ticket
as "worksforme" :slight_smile:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 neteler]:
be used for nodata.
If there are NULL cells in the bands to be exported, a valid value
according to the selected output data type needs to be selected to
represent nodata, otherwise NULL cells can not be encoded, e.g. for Byte,
the value representing nodata must be in the range 0-255. This is why you
see "Checking GDAL data type and nodata value..." in the output of
r.out.gdal. The module does not always choose 0 as nodata value, this
depends on the input bands and the selected output data type.
> Yes, I thought so.
ticket as "worksforme" :slight_smile:
You would need to create an alpha channel that encodes NULL cells and in
the bands to be exported replace NULL cells with some value in the range
0-255. For example
RMAP="lsat7_2000_30"
GMAP="lsat7_2000_20"
BMAP="lsat7_2000_10"
OUTNAME="lsat7_2000.tif"
# extract alpha
r.mapcalc "out_a = if(isnull($RMAP) || isnull($GMAP) || isnull($BMAP), 0,
255)"
# replace NULL cells with a valid value, extract colors
# extract red
r.mapcalc "out_r = if(isnull($RMAP), 0, #$RMAP)"
# extract green
r.mapcalc "out_g = if(isnull($GMAP), 0, #$GMAP)"
# extract blue
r.mapcalc "out_b = if(isnull($BMAP), 0, #$BMAP)"
# create group
i.group group=out_rgba input=out_r,out_g,out_b,out_a
# remove any MASK because this works only if there are
# no NULL cells in the bands to be exported
r.mask -r
# export the group
# add PROFILE=BASELINE to createopt to produce a standard TIFF file
without out GTiff extensions
r.out.gdal in=out_rgba out=$OUTNAME -cm
createopt="PHOTOMETRIC=RGB,ALPHA=YES"
A nice enhancement to r.out.gdal would be to accept multiple input raster
maps, this would avoid the need to create a group just for exporting
multiple raster maps into a single GDAL raster dataset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:3&gt;
The example works nicely, thanks! If no objections, I'll add it to the
manual.
Yet a question:
With Sentinel-2, also 0 is used as a data value (eg `Computed
Min/Max=0.000,13668.000`). The black border mask can be retrieved from an
auxiliary JP2000 file and applied as MASK in GRASS GIS. So far so nice.
Still I am not sure if it now better to use `r.rescale` or the `#`
operator of `r.mapcalc` with some formula in order to "free up" the 0
value for paving the way of exporting with alpha as above?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:4&gt;
Comment (by mmetz):
Replying to [comment:4 neteler]:
Using a nodata value means that any band values equal to the nodata value
will be interpreted as nodata. Using an alpha channel means that all
pixels with an alpha value of 0 are transparent. The alpha channel thus
represents per-pixel encoding of nodata, just like the GRASS null file.
That means when using an alpha channel, you do not need to "free up" any
particular value, you can use any value you like to replace NULL cells, as
long as the value can be represented by the Byte data type. It does not
matter if that value is already present in any of the input bands.
This is about exporting RGB data, not GIS data, therefore the `#` operator
of `r.mapcalc` needs to be used. The result is a regular image (like a
screenshot) that can be displayed by any simple image viewer coming with
your OS and/or desktop environment. When exporting, do you want to provide
something like a screenshot or the actual data?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:5&gt;
Component: Docs | Version: svn-releasebranch72
Resolution: | Keywords: r.out.gdal, alpha
Changes (by neteler):
* keywords: r.out.gdal => r.out.gdal, alpha
* component: Raster => Docs
Comment:
Replying to [comment:5 mmetz]:
operator of `r.mapcalc` needs to be used. The result is a regular image
(like a screenshot) that can be displayed by any simple image viewer
coming with your OS and/or desktop environment. When exporting, do you
want to provide something like a screenshot or the actual data?
Yes exactly. Here it is for showing the data in a Web system. I have taken
liberty to write up an example for the manual page from your comments,
r69162. Thanks for the explanations.
(an example backport needs r69128 and r69131 - they works nicely for me in
a local 7.2.svn backport).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:6&gt;
Comment (by mmetz):
Replying to [comment:6 neteler]:
> [...] I have taken liberty to write up an example for the manual page
from your comments, r69162. Thanks for the explanations.
in a local 7.2.svn backport).
r68128 has already been backported to relbr72 and relbr70 in r69129,30.
r69131 is not relevant. Please feel free to backport the example.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:7&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: r.out.gdal, alpha
* status: new => closed
* resolution: => fixed
Comment:
Example backported in r69265. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3130#comment:8&gt;
