#3131: d.legend.vect workspace file flag problem
Reporter: kuszinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Display | Version: unspecified
Keywords: workspace, legend, vector | CPU: Unspecified
Platform: Unspecified |
Switching on verbose and overwrite flags in they are save in the workspace
file like this, causing further porblems (see the many flags generated):
GRASS Last Changed Rev: 69107
d.legend.vect: as today 12 Aug, 2016
After loading the saved workspace, the vector legend won't come back
because of this error but stays in the workspace file in unaccessible
conditions. Users Should erase it with a text editor.
Priority: normal | Milestone: 7.4.0
Resolution: | Keywords: workspace, legend, vector
Comment (by annakrat):
In [changeset:"69450" 69450]:
#!CommitTicketReference repository="" revision="69450"
wxGUI: fix saving long flags of overlays to workspace, see #3131
In [changeset:"69451" 69451]:
#!CommitTicketReference repository="" revision="69451"
wxGUI: fix saving long flags of overlays to workspace, see #3131 (merge
from trunk, r69450)
