[GRASS-dev] [GRASS GIS] #3139: v.in.ogr UI flaws
Reporter: dido | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Vector | Version: 7.0.2
Keywords: v.in.ogr window | CPU: x86-64
Platform: MSWindows 7 |
Reporting here two flaws in v.in.ogr I've noticed:
1.It seems that v.in.ogr's tool window is not created as a standalone
window but part of/child of the main Layer Manager window. In Windows OS,
you can usually select from the toolbar every other opened tool by
clicking its window title EXCEPT the v.in.ogr tool, which is selected in
the toolbar when you click the Layer Manager's window name. This behavior
is inconsistent with the other tools behavior and should be changed.
2. v.in.ogr is missing the 'snap' field in the UI which is quite often
used when importing polygons with glitches.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3139&gt;
      Type: enhancement | Status: closed
  Priority: normal | Milestone: 7.6.2
Resolution: fixed | Keywords: v.in.ogr window
       CPU: x86-64 | Platform: MSWindows 7
Changes (by martinl):
* status: new => closed
* resolution: => fixed
* milestone: 7.0.7 => 7.6.2
Comment:
1. unable to reproduce
2. `Import settings -> Snap`
Ticket URL: <https://trac.osgeo.org/grass/ticket/3139#comment:3&gt;
