#314: wxgrass: delete point map geometry when deleting attribute
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: digitizer | Platform: All
Cpu: All |
Trying to eliminate points in wxgrass via attribute table editing "fails"
since not implemented. Would it be possible to add to the dialog in the
digitizer that optionally the associated geometry is removed, too?
You can delete features selected by attributes directly from attribute
manager -> contextual menu 'Delete selected features'.
* Vector map is not open for editing
-> v.edit is called on the background
* Vector map is open for editing
1) Select features from attribute manager, contextual menu 'Highlight &
delete selected'.
2) Select features from attribute manager, contextual menu 'Highlight',
choose 'Delete' tool from vdigit toolbar, right click to delete selected
features.
