[GRASS-dev] [GRASS GIS] #3142: Implementing SLIC image segmentation
Reporter: SCrommelinck | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Keywords: SLIC image segmentation | CPU: Unspecified
Platform: Unspecified |
Would someone be interested in implementing Simple Linear Iterative
Clustering (SLIC) image segmentation in GRASS?
References:
http://ivrl.epfl.ch/research/superpixels
http://docs.opencv.org/trunk/df/d6c/group__ximgproc__superpixel.html
http://scikit-
image.org/docs/dev/api/skimage.segmentation.html#skimage.segmentation.slic
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142&gt;
  Priority: normal | Milestone: 7.2.0
Component: Imagery | Version: unspecified
Resolution: | Keywords: SLIC image segmentation
Changes (by neteler):
* component: Default => Imagery
* milestone: 7.0.5 => 7.2.0
Old description:
References:
http://scikit-
New description:
References:
  * http://ivrl.epfl.ch/research/superpixels
  * http://docs.opencv.org/trunk/df/d6c/group__ximgproc__superpixel.html
  * http://scikit-
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:1&gt;
Comment (by tgrippa):
First of all, thank to GRASS GIS contributors for the great jobs they
make, especially for recent advances in segmentation :D.
In our lab (ANAGEO, Free University of Brussels), we moved recently from
proprietary software (eCognition) to GRASS GIS and we are very happy of
this change. As we are regularly confronted with large image datasets (>2
billion pixels with multispectral bands), we have to face quite important
processing time, which is an obstacle for dealing with "real" big
datasets. We hope that SLIC segmentation will be implemented in GRASS GIS,
which would allow us to save processing time and improve our ambitions.
Thank you
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:2&gt;
Comment (by mlennert):
After some discussion with MarkusM, I see three options, all based on the
source code published at [http://ivrl.epfl.ch/research/superpixels\], which
is GPL3:
  * Integrate the code as is into GRASS. Disadvantage: it's C++ and we
would have to maintain it. Advantage: code exists, so less work, we would
"only" have to write the GRASS io wrapper
  * Translate the original code to C and integrate into GRASS.
Disadvantage: more work, we have to maintain; Advantage: no C++, no
installation by user, native implementation in GRASS
  * Write a GRASS module that calls the compiled command line tool.
Disadvantage: the user would have to install and compile the code.
Advantage: less work for us, others maintain
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:3&gt;
Comment (by rashadkm):
Replying to [comment:3 mlennert]:
the source code published at [http://ivrl.epfl.ch/research/superpixels\],
which is GPL3:
mortiz,
the second option seems better than others. right?
first is okay, if we need to drag in c++. but still there needs to be some
additional work.
why not write new grass module. we can port/copy/translate those c++
methods into using grass api wherever possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:4&gt;
Replying to [comment:4 rashadkm]:
which is GPL3:
> mortiz,
I personally would prefer it, yes, but it means more work and someone has
to do it. Are you volunteering ? :slight_smile:
+1 (with the above reservations).
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:5&gt;
Replying to [comment:5 mlennert]:
on the source code published at
[http://ivrl.epfl.ch/research/superpixels\], which is GPL3:
we would have to maintain it. Advantage: code exists, so less work, we
would "only" have to write the GRASS io wrapper
> > mortiz,
has to do it. Are you volunteering ? :slight_smile:
I am interested to work.. given help from all grass devs ;).
> Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:6&gt;
Replying to [comment:6 rashadkm]:
> > > mortiz,
Well, maybe not all, but I'm willing to help, and we should definitely
have MarkusM on board.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:7&gt;
Thanks. I will be back hopefully with some code :-). I will definitely
ping back if have questions. Either here or on grass-dev.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:8&gt;
Comment (by mmetz):
Replying to [comment:7 mlennert]:
based on the source code published at
and we would have to maintain it. Advantage: code exists, so less work, we
tool. Disadvantage: the user would have to install and compile the code.
> > > > mortiz,
someone has to do it. Are you volunteering ? :slight_smile:
I am on board. SLIC(O) is an interesting method, and I would be happy to
help with the implementation. I would also prefer the second option, even
if it means more work, but the result might be more stable/portable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:9&gt;
Ok, so we agree on option 2, i.e. a native GRASS implementation
translating the original C++ code.
And as Markus mentions it should include the SLICO version. Maybe as a
flag ? Something like: i.superpixels.slic with a flag -o for SLICO ? Or
i.slic -o ? Or i.segment.slic ? If we plan on implementing other
superpixel approaches the i.superpixels.slic might be the way to go...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:10&gt;
could i.segment have an option to choose between slic and other ones?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:11&gt;
Replying to [comment:11 rashadkm]:
It's possible, but:
* SLIC itself is complex enough that MarkusM suggested it should go into a
separate module to not overcharge i.segment
* From what I've seen up to now, the use of superpixels in remote sensing
is mostly to reduce the number of "pixels" to treat for segmentation. In
that sense the "segmentation" into superpixels is not exactly the same as
segmentation using other algorithms. But my experience is limited and the
differences I see are more semantic than anything else.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:12&gt;
Okay. in that case we should decide on module name. i.superpixels.slic or
i.segment.slic ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:13&gt;
Replying to [comment:13 rashadkm]:
or i.segment.slic ?
I think i.superpixels.slic is more interesting in perspective of further
development of other superpixels methods, but it's only my opinion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:14&gt;
For information, the Windows GUI which was provided in the EPFL website
(http://ivrl.epfl.ch/research/superpixels) didn't generate the .dat file
containing the segment labels. I contacted the author (Achanta
Radhakrishna) who fix this. The version on the website is the fixed one.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:15&gt;
Comment (by mmetz):
Replying to [comment:15 tgrippa]:
I suggest to continue the discussion about details of the implementation
of SLIC(O) in GRASS in the mailing list or offlist in order to not crowd
this ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:16&gt;
  Priority: normal | Milestone: 7.2.1
here is first version on grass7 addons:
https://trac.osgeo.org/grass/browser/grass-
addons/grass7/imagery/i.superpixels.slic
can we close this ticket?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:18&gt;
Replying to [comment:18 rashadkm]:
There are still one [https://lists.osgeo.org/pipermail/grass-
dev/2017-January/083745.html comment from Markus] that you didn't apply:
the memory allocation for distvec. Just uncomment
[https://trac.osgeo.org/grass/browser/grass-
addons/grass7/imagery/i.superpixels.slic/main.c#L353 lines 353 and
following], not forgetting to add the G_free() call later (see the patch
in #3247). Otherwise the memory is allocated in the stack, where there
might not be enough available, rather than the heap.
When this is done, I agree that this ticket can be closed and we can open
new tickets for any other problems.
However, while you're at it: could you also consider the two additions
proposed in that same patch of #3247, assigning a color table and adding
the module call to the raster map's history ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:19&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: SLIC image segmentation
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
i.superpixels.slic is now available as an addon, so closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:20&gt;
