#3145: v.unpack: too sensitive to difference of names in projections
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: svn-trunk
Keywords: v.unpack projection | CPU: Unspecified
Platform: Unspecified |
Trying to use v.unpack I got the following error:
ATTENTION: Difference between PROJ_INFO file of packed map and of current
- name: Belge 1972 / Belgian Lambert 72
+ name: Lambert Conformal Conic
+ proj: lcc
datum: bel72
ellps: international
- proj: lcc
lat_1: 51.16666723333333
lat_2: 49.8333339
lat_0: 90
lon_0: 4.367486666666666
x_0: 150000.013
y_0: 5400088.438
no_defs: defined
AFAIU, the difference in position of "proj: lcc" is not the problem, it is
only the difference in projection names. Maybe v.unpack could/should
ignore a difference of names if all the other parameters are the same ?
I don't remember how this location was created (based on a file, perhaps),
but as you can see the parameters are strictly identical, it's just the
name that differs.
v.unpack uses compare_key_value_text_files from lib/python/script/core.py.
Maybe a solution would be to add to that function a list of keys to skip
and then v.unpack could add 'name' as a key to skip. Thus, if all other
parameters are equal the projection test wouldn't fail.
