[GRASS-dev] [GRASS GIS] #3148: d.wms cannot move temp file with os.rename
Reporter: kuszinger | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Display | Version: svn-trunk
Keywords: wms, display | CPU: Unspecified
Platform: Linux |
In Python on some Linuces/Unices os.rename won't work when the source and
target are on different physical volumes. This is a known Python
limitation in os.rename().
Solution is import shutil and use that for file moving (=renaming)
Household tested, works :slight_smile:
import os
import sys
+import shutil
And then:
     # os.rename(temp_map, os.environ["GRASS_RENDER_FILE"])
     shutil.move(temp_map, os.environ["GRASS_RENDER_FILE"])
I have no access to dev SVN ( and this is just good like this :slight_smile: - so I
post the ticket and solution here.
I recommend to fix it also back in 7.2 if possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3148&gt;
Resolution: | Keywords: wms, display
       CPU: Unspecified | Platform: Linux
Comment (by martinl):
In [changeset:"69429" 69429]:
#!CommitTicketReference repository="" revision="69429"
d.wms cannot move temp file with os.rename (see #3148
Ticket URL: </ticket/3148#comment:1>
In [changeset:"69430" 69430]:
#!CommitTicketReference repository="" revision="69430"
d.wms cannot move temp file with os.rename (see #3148)
Ticket URL: </ticket/3148#comment:2>
      Type: defect | Status: closed
Resolution: fixed | Keywords: wms, display
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"69431" 69431]:
#!CommitTicketReference repository="" revision="69431"
d.wms cannot move temp file with os.rename (fix #3148)
Ticket URL: </ticket/3148#comment:3>
  Priority: normal | Milestone: 7.0.5
* milestone: 7.2.0 => 7.0.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/3148#comment:4&gt;
