#3149: Adding database information to v.info metadata output
Reporter: huhabla | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-releasebranch72
Resolution: | Keywords: vector, info, v.info
Comment (by huhabla):
Replying to [comment:6 mlennert]:
> Replying to [comment:5 huhabla]:
> > Replying to [comment:4 mlennert]:
> > > Replying to [comment:3 huhabla]:
> > > >The output of v.db.connect -g is not well
> > > >designed for parsing, neither for bash
> > > >nor for the python-grass-script library.
> > > Then let us improve that
> > I guess there was a specific reason behind the implementation of the
"-g" flag in v.db.connect in the way it is. I fear to break existing
functionality when modifying v.db.connect "-g" flag output.
> > Since we do not have enough module tests, it would be hard to figure
out what will break in existing modules, in examples and documented work
flows and even more harder to figure out if extensions will break.
> One option could be to create another flag (-f?) which would "unFlatten"
the output of -f and provide a key=value output.
The "-g" flag is used for key-value shell output in many modules, adding a
new flag to generate shell output is counter intuitive and makes the code
more complicated.
> > > Just to be clear: this is not a -1 to your idea. I just want to make
sure we think about it. In general, I'm wary of introducing the same
functionality in two different modules. IMHO, it creates the risk of
feature bloat and of confusion for the users.
> > IMHO the database connection is vector map metadata that should be
available within v.info, so the user does not have to search for another
module to get this information. The default settings of vector layer
database management usually does not require the user to use v.db.connect,
hence its capabilities is mostly unknown to the user.
> I understand the concern, but remain afraid that such logic leads to
feature bloat of modules as many things would be nice to have in one
single module. But then again, I'm probably just biased as I started using
GRASS before the advent of v.db.*...
I agree, adding unnecessary flags to modules will lead to feature bloat.
And i agree that a single module to access information (for example
metadata) without adding additional flags is preferable.
If i would need to add new flags or options to v.info to display the
database connection metadata, i wouldn't implement it. The suggested
implementation simply adds the database connection info to the -e flag the
"extended metadata" of v.info. Only some lines of code are added, no new
feature, no highly redundant code, no esoteric information.
> > I think the less invasive solution is to modify v.info, especially
since i have already implemented 6 tests to verify the functionality.
> As much as I understand that already done work would be frustrating to
abandon, I don't think that this should enter into account in this
discussion...
Indeed.
> > BTW, v.info is an integral part of the gunittest validation approach,
hence the more metadata information about a vector map is available via
v.info, the easier it is to implement tests.
> Because otherwise you have to call two modules ? Again, I would not want
test creation logic to be what decides about module functionality.
Why call two modules to get the information that a single module should
provide? And why shouldn't test logic be used to define module
functionality? How about if the test logic, which is in our case dedicated
to test GRASS functionality, exposes inconsistent logic or inconsistent
output definitions in modules? Should we ignore this, because it was found
by test logic? In this specific case i realized, that the database
information is missing in v.info and that tests can't be implemented to
check for database connection parameters easily.
Our GRASS gunittest environment should not depend on to many modules to
check correct module or API test runs. This would be bad design, to many
points of failure. Hence, test logic will influence module design.
> But I'll shut up now and let you go on with your work. As others don't
seem to share my worries, this is probably me just rambling on a hangover
Sunday...
Don't worry, it is always good to argue about specific changes. We all
have different opinions and biases about implementation and user
experience. Its good to exchange arguments to come to a consent. I will
wait for more concerns before i apply the patch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3149#comment:7>
