[GRASS-dev] [GRASS GIS] #3155: inconsistent newlines handling on Windows
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: LibVector | Version: svn-trunk
Keywords: newline | CPU: Unspecified
Platform: MSWindows 8 |
Function [https://grass.osgeo.org/programming7/ascii_8c_source.html#l00336
Vect_write_ascii] uses:
fprintf(ascii, "%s", HOST_NEWLINE);
where HOST_NEWLINE is defined as '\r\n' on Windows.
Other modules like v.info use:
fprintf(stdout, "north=%s\n", tmp1);
This is problem when you process the output in Python:
>>> output_points = grass.read_command("v.out.ascii", input='hospitals',
format="point", separator=",").strip()
>>> repr(output_points)
'697237.5638615,182012.65540056,1\r\r\n704563.1878615,183568.90640056,2\r\r\n371094.1568615,274897.21940056,3\r\r\n640607.6248615,224673.12440056,4\r\r\n640952.4998615,224309.56340056,5\r\r\n670385.0618615,229717.53040056,6\r\r\n643879.5628615,230462.43740056,7\r\r\n636274.0638615,229165.37540056,8\r\r\n627390.7508615,202760.56240056,9\r\r\n646823.5628615,226063.35940056,10\r\r\n206065.7348615,195917.60840056,11\r\r\n444744.4678615,280199.56340056,12\r\r\n501025.1878615,179551.84440056,13\r\r\n566335.3748615,111190.14840056,14\r\r\n566327.6258615,111195.04740056,15\r\r\n671357.9988615,139627.76540056,16...
but:
x= grass.read_command('v.info', map='hospitals', flags='g')
repr(x)
'north=308097.937400562\r\nsouth=20235.5644005626\r\neast=914347.8748615\r\nwest=156998.1718615\r\ntop=0.000000\r\nbottom=0.000000\r\n'
so you have '\r\r\n' instead of '\r\n' which results in problems:
>>> output_points.splitlines()
['640607.6248615,224673.12440056,4', '',
'640952.4998615,224309.56340056,5', ' ', ...]
Should we stop using 'HOST_NEWLINE' then?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3155&gt;
Resolution: | Keywords: newline
       CPU: Unspecified | Platform: MSWindows 8
Comment (by neteler):
Sounds like https://stackoverflow.com/questions/4599936/handling-r-n-vs-n
-newlines-in-python-on-mac-vs-windows
Ticket URL: <https://trac.osgeo.org/grass/ticket/3155#comment:1&gt;
  Priority: normal | Milestone: 7.2.1
Changes (by annakrat):
* milestone: 7.2.0 => 7.2.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3155#comment:2&gt;
Comment (by wenzeslaus):
It actually sounds more like http://stackoverflow.com/questions/11497376
/new-line-python, specifically Nate C-K's comment to Charlie Martin's
answer, except that `fprintf(ascii, "%s", HOST_NEWLINE);` is in C.
It seems that HOST_NEWLINE being `\r\n` on Windows is passed to
`fprintf()` which seems to automatically replace `\n` by `\r\n` resulting
in `\r\n\n` in the file (which is what is not possible to parse later in
Python).
[http://www.open-std.org/jtc1/sc22/wg14/www/docs/n1256.pdf ISO/IEC
9899:TC3] says:
> 5.2.2 Character display semantics
> Alphabetic escape sequences representing nongraphic characters in the
execution character set are > intended to produce actions on display de
vices as follows:
> * \n (new line) Moves the active position to the initial position of the
next line.
> * \r (carriage return) Moves the active position to the initial position
of the current line.
[https://en.wikipedia.org/wiki/Newline#In_programming_languages Wikipedia]
says:
> The C standard only guarantees two things:
> * Each of these escape sequences maps to a unique implementation-defined
number that can be stored in a single char value.
> * When writing a file in text mode, '\n' is transparently translated to
the native newline sequence used by the system, which may be longer than
one character. When reading in text mode, the native newline sequence is
translated back to '\n'. In binary mode, no translation is performed, and
the internal representation produced by '\n' is output directly.
The behavior fits what these two resources say, so it seems that
`HOST_NEWLINE` can be changed to always mean `\n` and/or not used at all.
`HOST_NEWLINE` seems to be used only in `lib/vector/Vlib/ascii.c`,
`i.cluster`, and `v.out.ascii`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3155#comment:3&gt;
  Priority: normal | Milestone: 7.6.2
Changes (by hellik):
* milestone: 7.2.4 => 7.6.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3155#comment:8&gt;
