[GRASS-dev] [GRASS GIS] #3157: support for "offset" and "num_digits" in r.import
Reporter: veroandreo | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Keywords: r.import | CPU: Unspecified
Platform: Unspecified |
It would be nice to have the options "offset" and "num_digits" from
G7:r.in.gdal also in G7:r.import. These options make it easier to work
with multiband maps, as those provided for example in ECAD dataset, given
that the zero padding in the imported map names allows then for ordered
listing of resulting maps.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3157&gt;
Resolution: | Keywords: r.import
Comment (by mmetz):
Replying to [ticket:3157 veroandreo]:
The purpose of the [r|v].import modules is to provide a simplified
interface for easy import of spatial data, combining r.in.gdal + r.proj
and v.in.ogr + v.proj. That means a reduced number of options to keep the
interface simple and some checks if the data can indeed be reprojected if
need be.
Despite the existence of [r|v].import, it is always safer to use r.in.gdal
+ r.proj and v.in.ogr + v.proj separately because [r|v].import do not
catch all problems that can occur when 1) importing data, 2) reprojecting
data.
Therefore I propose to have a nice GUI interface for r.import/v.import
similar to the current GUI interface for r.in.gdal/v.in.ogr. At the very
least, the selection of the input type (file, directory, database,
protocol) should be available. The default GUI interface for
r.in.gdal/v.in.ogr can then be again what you get with e.g. r.in.gdal
--ui. We would then have a relatively simple and comfortable method +
interface for importing "easy" data provided by [r|v].import and the full
options, also in the GUI interface of r.in.gdal/v.in.ogr for the not-so-
easy data to be imported.
IOW, [r|v].import should IMHO provide a simple (simplified) interface to
easily import data with reprojection on-the-fly. If [r|v].import fails, or
if you want more control over the import process, you should have access
to all the options of r.in.gdal/v.in.ogr also through the GUI.
BTW, the default answers of r.import for extent=input and
resolution=estimated seem dangerous to me.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3157#comment:1&gt;
