[GRASS-dev] [GRASS GIS] #3158: r.watershed: PredictorSetup:Horizontal differencing "Predictor" not supported with 64-bit samples
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.2.0
Component: Raster | Version: svn-
                                             | releasebranch72
Keywords: libtiff, r.watershed, libraster | CPU: Unspecified
Platform: Unspecified |
GRASS 7.2.svn (nc_spm_08_grass7): > g.region raster=elev_lid792_1m
GRASS 7.2.svn (nc_spm_08_grass7): > r.watershed elevation=elev_lid792_1m
accumulation=elev_lid792_1m_accu
SECTION 1a (of 4): Initiating Memory.
SECTION 1b (of 4): Determining Offmap Flow.
  100%
SECTION 2: A* Search.
  100%
SECTION 3a: Accumulating Surface Flow with MFD.
  100%
SECTION 3b: Adjusting drainage directions.
  100%
SECTION 4: Closing Maps.
ERROR 1: PredictorSetup:Horizontal differencing "Predictor" not supported
with 64-bit samples
with 64-bit samples
g.version -eg
version=7.2.svn
date=2016
revision=r69482M
build_date=2016-09-14
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
proj4=4.9.2
gdal=2.0.2
geos=3.5.0
sqlite=3.13.0
Do we have a namespace collision with GDAL?
[neteler@oboe gdal-2.1.svn]$ !find
find . -type f | grep -v 'svn/pristine' | xargs grep PredictorSetup
./frmts/gtiff/libtiff/gdal_libtiff_symbol_rename.h:#define PredictorSetup
gdal_PredictorSetup
PredictorSetupDecode gdal_PredictorSetupDecode
PredictorSetupEncode gdal_PredictorSetupEncode
./frmts/gtiff/libtiff/tif_predict.c:PredictorSetup(TIFF* tif)
./frmts/gtiff/libtiff/tif_predict.c: static const char module =
"PredictorSetup";
./frmts/gtiff/libtiff/tif_predict.c:PredictorSetupDecode(TIFF* tif)
./frmts/gtiff/libtiff/tif_predict.c: if (!(*sp->setupdecode)(tif) ||
!PredictorSetup(tif))
./frmts/gtiff/libtiff/tif_predict.c:PredictorSetupEncode(TIFF* tif)
./frmts/gtiff/libtiff/tif_predict.c: if (!(*sp->setupencode)(tif) ||
./frmts/gtiff/libtiff/tif_predict.c: tif->tif_setupdecode =
PredictorSetupDecode;
./frmts/gtiff/libtiff/tif_predict.c: tif->tif_setupencode =
PredictorSetupEncode;
System:
uname -a
Linux oboe.localdomain 4.6.6-300.fc24.x86_64 #1 SMP Wed Aug 10 21:07:35
UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
gcc -v
Using built-in specs.
COLLECT_GCC=/usr/bin/gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/6.1.1/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../configure --enable-bootstrap --enable-
languages=c,c++,objc,obj-c++,fortran,ada,go,lto --prefix=/usr
--mandir=/usr/share/man --infodir=/usr/share/info --with-
bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-
threads=posix --enable-checking=release --enable-multilib --with-system-
zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-
unique-object --enable-linker-build-id --with-linker-hash-style=gnu
--enable-plugin --enable-initfini-array --disable-libgcj --with-isl
--enable-libmpx --enable-gnu-indirect-function --with-tune=generic --with-
arch_32=i686 --build=x86_64-redhat-linux
Thread model: posix
gcc version 6.1.1 20160621 (Red Hat 6.1.1-3) (GCC)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3158&gt;
Component: Raster | Version: svn-releasebranch72
Resolution: | Keywords: libtiff, r.watershed, libraster
Comment (by mmetz):
Replying to [ticket:3158 neteler]:
> 100%
> 100%
> 100%
> 100%
> g.version -eg
> version=7.2.svn
> date=2016
> revision=r69482M
> build_off_t_size=8
> proj4=4.9.2
> gdal=2.0.2
> geos=3.5.0
> sqlite=3.13.0
What is the output of
r.external.out -p
This error can only happen with PREDICTOR=2 as a GTiff creation option.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3158#comment:1&gt;
Comment (by neteler):
Oh, I completely forgot that I had set r.external.out some months ago in
that mapset.
r.external.out -p
directory: /home/neteler/tmp
extension: .tif
format: GTiff
options: COMPRESS=LZW,PREDICTOR=2
It would be great to improve the error message above with a related hint
to check r.external.out.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3158#comment:2&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: libtiff, r.watershed, libraster
Changes (by neteler):
* status: new => closed
* resolution: => invalid
Ticket URL: <https://trac.osgeo.org/grass/ticket/3158#comment:3&gt;
