[GRASS-dev] [GRASS GIS] #3159: No label in output when using a point vector layer as in put in r.what
Reporter: pvanbosgeo | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
In ''r.what'' one can provide as input a text file with coordinates and
optionally a label, both which will be printed to the output file as well.
If using a point vector layer as input, there is no option to define the
label. The output text file includes two columns with the coordinates and
an empty column for the label.
It would be nice if one could define a column to serve as label, or
alternatively, to have ''r.what'' fill in the label column with the cat
values.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3159&gt;
  Priority: normal | Milestone: 7.0.6
Resolution: | Keywords:
Comment (by sbl):
Would be useful indeed, also in the temporal framework / t.rast.what (see:
#2564).
Ideally, one would get an option to provide a column for labeling.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3159#comment:2&gt;
  Priority: normal | Milestone: 7.0.7
Comment (by martinl):
Still relevant?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3159#comment:4&gt;
      Type: enhancement | Status: closed
  Priority: normal | Milestone: 7.4.5
Resolution: fixed | Keywords:
Changes (by sbl):
* status: new => closed
* resolution: => fixed
* milestone: 7.0.7 => 7.4.5
Comment:
Fixed in r71091
Ticket URL: <https://trac.osgeo.org/grass/ticket/3159#comment:5&gt;
