#3160: g.gui.animation: enhance display of stvds that contain time periods with
no-data
Reporter: veroandreo | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.0
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.animation, stvds | CPU: Unspecified
Platform: Unspecified |
For vector time series with no-data time periods, the animation is sub-
optimal as it is currently. For example, I have weekly vector maps
(points) that represent the occurrence of disease cases. These cases
appear only in certain weeks of the year (summer weeks). I registered my
weekly vectors of disease cases as a STVDS to make use of time
information.
However, none of the solutions provided in G7:g.gui.animation is optimal
to display this kind of data (STVDS). The options available are: 1) to
display time periods of no-data (periods of no cases occurrences) and 2)
to NOT display time periods of no-data.
If I choose to display time periods of no-data (no disease cases), I get
black screens when there are no cases (which is most of the year). That
makes the animation a bit ugly.
On the other hand, if I choose to NOT display those time periods in which
there are no cases, I get the last disease cases that appeared frozen
there for most of the year, i.e: the last vector map with data remains
frozen until new vector maps with cases are reached. At least for this
particular case, that behavior is not correct nor desirable. It would mean
that there's always someone reporting a disease case in that place, which
is not true in the data.
So, during those parts of the year with no data (no disease cases
occurrence), I would expect to only see the background raster I choose,
i.e.: no frozen last vector map, only the raster I had added as
background.
I know passing a list of vectors instead of a STVDS solves the issue of
periods with no data, but I loose time info which was the whole point.
Thanks a lot
Ticket URL: <https://trac.osgeo.org/grass/ticket/3160>
