GDAL
September 27, 2016, 4:43pm
1
#3169: use external shapelib
Reporter: opoplawski | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Keywords: | CPU: Unspecified
Platform: Unspecified |
Is there any reason at this point to not compile against an external
shapelib?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3169> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
September 27, 2016, 4:57pm
2
Resolution: | Keywords:
Comment (by opoplawski):
See also issue #1318
Ticket URL: <https://trac.osgeo.org/grass/ticket/3169#comment:1> ;
GDAL
September 29, 2016, 4:31pm
3
Priority: normal | Milestone: 7.2.1
Component: LibVector | Version: svn-releasebranch72
Resolution: | Keywords: shapelib, OGR
Changes (by neteler):
* keywords: => shapelib, OGR
* version: 7.0.4 => svn-releasebranch72
* component: Default => LibVector
* milestone: 7.0.5 => 7.2.1
Comment:
Replying to [ticket:3169 opoplawski]:
shapelib?
AFAIR we picked shapelib many years ago from http://shapelib.maptools.org/
(points to http://download.osgeo.org/shapelib/ ). The last release appears
to be from 2012 since it then became part of OGR
(https://trac.osgeo.org/gdal/browser/branches/2.1/gdal/ogr/ogrsf_frmts/shape ).
Here is what we changed after that (for some years we kept it in sync with
OGR, then lost track due to the needed effort). For the procedure, see
https://trac.osgeo.org/grass/browser/grass/trunk/lib/external/shapelib/README
The real question is: cannot we call the shape driver via OGR interface
and drop our own copy?
Ticket URL: <http://trac.osgeo.org/grass/ticket/3169#comment:2> ;
GDAL
September 30, 2016, 6:57am
4
Component: Database | Version: svn-releasebranch72
Changes (by mmetz):
* component: LibVector => Database
Comment:
Replying to [comment:2 neteler]:
shapelib?
http://shapelib.maptools.org/ (points to
http://download.osgeo.org/shapelib/ ). The last release appears to be from
with OGR, then lost track due to the needed effort). For the procedure,
see
GRASS needs lib/external/shapelib to read and write dbf files. We can not
use the OGR interface easily without rewriting db/drivers/dbf because
shapefil.h is not installed with OGR. Also, GRASS does not need the full
shapelib, only those parts relevant for dbf RW. An external shapelib is
usually not installed because shapefiles can be accessed with the generic
OGR interface.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3169#comment:3> ;
