[GRASS-dev] [GRASS GIS] #317: WinGRASS MSYS Console doesn't run correctly
Reporter: gislab | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: msys console | Platform: MSWindows XP
      Cpu: x86-32 |
1. Install GRASS in C:\GRASS
2. Check C:\GRASS\msys\home\, in this folder C\Documents and
Settings\MYNAME is created during install, where grass63 is sitting.
3. Run Start\Programs\GRASS\GRASS MSYS Console
4. Check C:\Gis\GRASS\msys\home\ again, now in this folder MYNAME
(lowercase) folder is created, without grass63 file in it.
Needless to say, that even if I move grass63 from the folder made
right after install
"C:\GRASS\msys\home\C\Documents and Settings\MYNAME"
to the one created on first run of MSYS
"C:\GRASS\msys\home\MYNAME"
GRASS GUI starts with error messages, grass63 -text doesn't start at all,
producing "Redirection is not supported" message.
Removing .grassrc6 from C:\GRASS\msys\home\C\Documents and
Settings\USERNAME\
and .grassrc6 from C:\Documents and Settings\USERNAME\
doesn't help.
The problem was replicated on at least 4 more machines by other
people under the same operating system and grass version.
http://lists.osgeo.org/pipermail/grass-windows/2008-September/001502.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/317&gt;
Resolution: | Keywords: msys console
  Platform: MSWindows XP | Cpu: x86-32
Comment (by neteler):
Could you please test the new OSGeo4W installer:
http://trac.osgeo.org/osgeo4w/
Ticket URL: <http://trac.osgeo.org/grass/ticket/317#comment:1&gt;
Old description:
right after install
Settings\USERNAME\
doesn't help.
New description:
right after install
Settings\USERNAME\
doesn't help.
Recent GRASS 6.4 should no longer have (much?) problems with white space
in the install path. Please retry with a new winGRASS version from
http://josef.fsv.cvut.cz/wingrass/grass64/
Ticket URL: <http://trac.osgeo.org/grass/ticket/317#comment:2&gt;
Component: default | Version: 6.3.0
Resolution: | Keywords: msys console, wingrass
Changes (by hamish):
  * keywords: msys console => msys console, wingrass
  * version: unspecified => 6.3.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/317#comment:3&gt;
Reporter: gislab | Owner: grass-dev@…
Keywords: msys console, wingrass | Platform: MSWindows XP
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:2 neteler]:
still valid for nightly builds of WinGrass64?
closing the ticket related to WinGrass63?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/317#comment:4&gt;
      Cpu: x86-32 |
Comment(by hamish):
only if it's fixed in grass 6.4 ..
Ticket URL: <https://trac.osgeo.org/grass/ticket/317#comment:5&gt;
      Type: defect | Status: closed
Component: Default | Version: 6.3.0
Resolution: fixed | Keywords: msys console, wingrass
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:5 hamish]:
should be fixed, please reopen if there are still some issues.
Ticket URL: <http://trac.osgeo.org/grass/ticket/317#comment:6&gt;
