#3170: GRASS_BATCH_JOB does not tolerate path with spaces
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Startup | Version: svn-trunk
Keywords: grass.py, init | CPU: Unspecified
Platform: Unspecified |
It is not possible to execute any GRASS_BATCH_JOB script form a path
containing spaces.
Executing </home/maris/my way/gol_batch.sh>....
/bin/sh: /home/maris/my: No such file or directory
Quoting or shell escaping also doesn't work due to
get_batch_job_from_env_variable checking file presence with os.access()
Workaround is to change line 1351 of grass.py to read:
proc = Popen('"' + batch_job + '"', shell=True)
As quoting of path is a delicate issue and there have been fights in other
parts of GRASS with Popen, I'll better leave for more experienced GRASS
Pythonists to decide if such workaround can be considered safe or more
serious changes are needed.
For 7.2 and 7.4 (and maybe 7.6) the workarounds are:
1. Don't use `GRASS_BATCH_JOB`, use more powerful `--exec` instead.
2. Don't use spaces in the path. (And please let us know why do you prefer
`GRASS_BATCH_JOB` rather over `--exec`.)
The spaces-in-path support can be implemented like this:
Here `shell=True` (which is splitting the command using spaces) is used
because it was used with `GRASS_BATCH_JOB` in the past. `--exec` is not
using `shell=True` and allows spaces. Note that for 8.0 there might be
changes to `GRASS_BATCH_JOB` in order to make it more aligned with
`--exec` (see wiki:Grass8Planning).
Reporter: marisn | Owner: wenzeslaus
Priority: normal | Milestone: 7.6.0
Resolution: | Keywords: grass.py init spaces exec
CPU: | GRASS_BATCH_JOB Popen shell=True
Unspecified | Platform: Unspecified
Comment (by marisn):
Replying to [comment:6 wenzeslaus]:
> And please let us know why do you prefer `GRASS_BATCH_JOB` rather over
`--exec`.
To be honest – I do not remember what was the reason of using
GRASS_BATCH_JOB and not --exec. May be just experimenting and stumbled on
a bug (as it is a bug per se).
Comment (by wenzeslaus):
Replying to [comment:7 marisn]:
`--exec`.
In [changeset:"73261" 73261]:
#!CommitTicketReference repository="" revision="73261"
init: support spaces in path for GRASS_BATCH_JOB (see #3170)
* priority: normal => trivial
* status: new => closed
* resolution: => fixed
* milestone: 7.6.0 => 7.8.0
Comment:
Since there is `--exec` (see above) and spaces are unlikely here,
backporting this is more trouble than it is worth. Let's have this more
tested and shipped in (or around) 7.8. ''(Thanks for creating that
milestone, BTW.)''
