[GRASS-dev] [GRASS GIS] #3177: Automatically register addons in GUI
Reporter: sbl | Owner: grass-dev@…
Priority: minor | Milestone: 7.4.0
Component: Addons | Version: unspecified
Keywords: g.extension,Makefile | CPU: Unspecified
Platform: All |
To make Addons more visible it would be nice if they could be registered
in the GUI at install (through g.extension or Makefile)
Related discussion on ML here:
https://lists.osgeo.org/pipermail/grass-dev/2016-October/082644.html
and here:
https://lists.osgeo.org/pipermail/grass-dev/2016-October/082668.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/3177&gt;
  Priority: minor | Milestone: 7.4.1
Resolution: | Keywords: g.extension,Makefile
       CPU: Unspecified | Platform: All
Comment (by martinl):
Already done, Addons are visible in Modules tab (after restarting the
GUI). Time to close this issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3177#comment:2&gt;
Comment (by hellik):
Replying to [comment:2 martinl]:
AFAIK only C addons are added to the Modules tab, but not python addons;
behaviour seen in winGRASS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3177#comment:3&gt;
Comment (by annakrat):
Replying to [comment:3 hellik]:
I am not sure if there is a separate ticket for this, but I looked at the
problem and I don't quite understand the logic behind it. Basically when
scanning for available addons, the toolboxes run g.extension -ag and look
if "executable" exists. For Python scripts it's not there:
grass.read_command('g.extension', quiet=True, flags='ag')
name=r.lake.series
description=Fills lake at given point(s) to given levels.
keywords=raster,hydrology,hazard,flood
executables=
name=r.stream.distance
description=Calculates distance to and elevation above streams and outlet.
The module can work in stream mode where target are streams and outlets
mode where targets are outlets.
keywords=raster,hydrology,stream network,watercourse distance
executables=r.stream.distance
name=i.superpixels.slic
description=Perform image segmentation using the SLIC segmentation method.
keywords=imagery,segmentation,superpixels,SLIC
executables=i.superpixels.slic
So the question is why the executable is not there, which is in
g.extension:
https://trac.osgeo.org/grass/browser/grass/trunk/scripts/g.extension/g.extension.py#L413
I don't understand the condition there to exclude scripts folder on
windows.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3177#comment:4&gt;
In [changeset:"72658" 72658]:
#!CommitTicketReference repository="" revision="72658"
wxGUI: fix problem with Python addons not showing up on Windows, see #3177
Ticket URL: <https://trac.osgeo.org/grass/ticket/3177#comment:5&gt;
In [changeset:"72659" 72659]:
#!CommitTicketReference repository="" revision="72659"
(merge from trunk, r72658)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3177#comment:6&gt;
  Priority: minor | Milestone: 7.4.2
Comment (by wenzeslaus):
Can somebody test this on MS Win? See if you have in ''Modules'' tab there
some Python module from Addons for example i.superpixels.slic.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3177#comment:8&gt;
  Priority: normal | Milestone: 7.8.0
Component: Addons | Version: svn-trunk
Changes (by neteler):
* priority: minor => normal
* version: unspecified => svn-trunk
* milestone: 7.6.2 => 7.8.0
Comment:
A (un?)related bug is that metamodules like r.modis, i.sentinel are not
listed properly in modules.xml cause they do not appear with description
and keywords in the xml file but are simply listed in the <binary>
section.
This prohibits the addon manual search, see #3583
Ticket URL: <https://trac.osgeo.org/grass/ticket/3177#comment:12&gt;
