[GRASS-dev] [GRASS GIS] #3179: g.extension not installing addons behind proxy
Reporter: madi | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Addons | Version: unspecified
Keywords: g.extension, proxy, addons | CPU: Unspecified
Platform: Unspecified |
Related to https://lists.osgeo.org/pipermail/grass-
user/2016-October/075337.html
when i try to use g.extension behind a proxy, following the example from
the manual, it gives me the following error:
g.extension ext=i.segment.hierarchical proxy="http://xx.xxx.xxx.xx:xxxx"
   File "/usr/local/grass-7.3.svn/scripts/g.extension", line 1730, in
<module>
     sys.exit(main())
   File "/usr/local/grass-7.3.svn/scripts/g.extension", line 1675, in main
     for ptype, purl in (p.split('=') for p in
options['proxy'].split(',')):
ValueError: need more than 1 value to unpack
Using the form suggested by Pietro:
proxy="http=<value>,ftp=<value>"
proxy="http=http://xx.xxx.xxx.xx:xxxx"
gives:
Fetching <i.segment.hierarchical> from GRASS GIS Addons repository (be
patient)...
ERROR: Extension <i.segment.hierarchical> not found
which is exactly the same as if I don't indicate the proxy at all.
FWIW, I normally use urllib2 to handle the proxy. However I have some
difficulties to apply this simple method to the 1700+ rows code (handling
several different addons sources for several os's) of g.extension, but I'm
behind a proxy and I'm available to test if you have a patch.
Here's what I do in python:
import urllib2
import os
proxy = urllib2.ProxyHandler({'http':os.environ['HTTP_PROXY']})
opener = urllib2.build_opener(proxy)
urllib2.install_opener(opener)
urllib2.urlopen('http://www.google.com')
Thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179&gt;
Resolution: | Keywords: g.extension, proxy, addons
Comment (by neteler):
Proxy ticket also in #1434
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:1&gt;
Please indicate the operating system, the output of `g.version -reg` and
the Python version.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:2&gt;
Comment (by madi):
Can't check this now, as I'm currently not behind a proxy. Operating
system at the time of reporting was CentOS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:3&gt;
Comment (by mmetz):
Replying to [ticket:3179 madi]:
<module>
> sys.exit(main())
main
> gives:
> patient)...
According to Python docs, "Proxies which require authentication for use
are not currently supported; this is considered an implementation
limitation" in urllib, and `g.extension` uses urllib, not urllib2 to open
urls.
> import urllib2
> import os
That should also work for `g.extension`, including authentification.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:4&gt;
  Priority: normal | Milestone: 7.4.5
Fix attempt via https://github.com/GRASS-GIS/grass-ci/pull/6 submitted as
r74116.
Note the different proxy syntax in the manual page.
If ok, to be backported.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:10&gt;
Comment (by mmetz):
Replying to [comment:10 neteler]:
as r74116.
Note, this is introducing a new python dependency, on RHEL 7 and
derivates, this is python-requests.
Do we have a list of required python 2 components and required python 3
components that can be updated? Ideally such a list would also indicate
which python components are required only for the GUI (systems such as HPC
may use GRASS without GUI).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:11&gt;
Replying to [comment:11 mmetz]:
as r74116.
Yes, I realized that today.
Also yes. See r74121, it is REQUIREMENTS.html.
> Ideally such a list would also indicate which python components are
required only for the GUI (systems such as HPC may use GRASS without GUI).
That's more or less indicated in that file.
So, I am undecided now about the backport.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:12&gt;
Comment (by mlennert):
Replying to [comment:12 neteler]:
submitted as r74116.
3 components that can be updated?
I would plead for reworking this to use urllib2 (Python 2) which is
already imported in the module and which seems to work according to madi.
IIUC, authenticated proxy handling is part of urllib in Python 3, or ?
Let's try to avoid the endless dependency hell just out of easy
availability of small helper packages. See the [https://hackernoon.com
/whats-really-wrong-with-node-modules-and-why-this-is-your-fault-
8ac9fa893823 experience] with npm in the Javascript world as a case in
point. I would plead to keep most modules down to standard python library
dependency, unless there really is no other way.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:13&gt;
Comment (by mmetz):
Replying to [comment:13 mlennert]:
python 3 components that can be updated?
+1
+1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:14&gt;
Comment (by annakrat):
In [changeset:"74374" 74374]:
#!CommitTicketReference repository="" revision="74374"
g.extension: avoid python requests import, see #3179
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:15&gt;
If somebody could test it with proxy, that would be great, I couldn't do
that now. This should work with Python 2/3, it uses six package (which we
need to require unlike requests).
If this works, we need to revert r74121.
As a side note, since we are moving to GitHub and we expect to get more
pull requests, we should be more strict about what we accept. People
typically care about getting a specific issue fixed, but this will often
introduce more mess in the code or even break other functionality.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:16&gt;
(just a comment on testing)
Yes, we need to have tests for much more code and instant testing.
Comment (by pmav99):
{{{requests}}} need to be removed from {{{REQUIREMENTS.html}}} and the
{{{Dockerfile}}}, too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:17&gt;
Component: Default | Version: unspecified
Changes (by martinl):
* component: Addons => Default
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:18&gt;
Comment (by mmetz):
Replying to [comment:17 pmav99]:
Done in trunk r74454
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:20&gt;
  Priority: normal | Milestone: 7.8.3
Comment (by sbl):
Is there anything left here? Can the ticket be closed? Installation
through proxies should work now...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:22&gt;
