[GRASS-dev] [GRASS GIS] #318: d.vect.thematic - I have enhanced some features - but wish more
Reporter: aprasad | Owner: grass-dev@lists.osgeo.org
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0
Keywords: | Platform: All
      Cpu: Unspecified |
NOTE: # I modified d.vect.thematic (see attached file) to put the legend
into png file if monitor=none and also to render thematic map into png
file if no monitor is running....I ALSO HAVE ONE ENHANCEMENT WISH I WILL
OUTLINE IN THE END....
Assuming that you have not started any monitors, it renders to png (starts
monitor png1) and outputs to ${map}_thematic.png. Also, if monitor=none,
the legend is rendered to ${map}_thematic_leg.png. I don't stop the png1
monitor in case you want to add other display commands - so, if you want
to add display commands to the ${map}_thematic.png after
d_vect_thematic.sh has run, simply do, for eg.:
d.mon sel=png1
d.vect ewstates type=boundary
d.mon stop=png1
This will be very useful for shell scripting of grass commands. You may
want to streamline the process to make the solution more elegant.
ENHANCEMENT WISH: Currently if you choose themecalc=custom_breaks
breakpoints=""
colorscheme=custom_gradient - you have the option to use just startcolor
and endcolor and let the script grade the colors in between. One would
want to use custom colors for each break - supplied as an option or as an
external file (RGB values etc.) using the breakpoints specified. This
seems like a logical thing to want and should not be difficult to
implement ... I will not attempt it as I am sure there are others who will
do it better and quicker.
Thanks much.
Ticket URL: <http://trac.osgeo.org/grass/ticket/318&gt;
Resolution: | Keywords:
  Platform: All | Cpu: Unspecified
Comment (by mlennert):
You might want to try the new (and hardly tested) d.thematic.area which is
in the grass6 dev branch and in the grass7 branch.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/318#comment:1&gt;
Resolution: | Keywords: d.vect.thematic
Changes (by martinl):
  * keywords: => d.vect.thematic
Ticket URL: <http://trac.osgeo.org/grass/ticket/318#comment:2&gt;
Reporter: aprasad | Owner: grass-dev@…
Component: Display | Version: 6.3.0
Keywords: d.vect.thematic | Platform: All
      Cpu: Unspecified |
Changes (by hamish):
  * component: Default => Display
Comment:
see also #321
Ticket URL: <https://trac.osgeo.org/grass/ticket/318#comment:3&gt;
