#3186: [PATCH] i.in.spotvgt: allow import of any band, not only NDVI
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.6
Component: Imagery | Version: svn-trunk
Resolution: | Keywords: i.in.spotvgt bands
Comment (by mlennert):
I've replaced the patch with a new one, that loops through all bands. By
default it only imports NDVI (as before), but by setting the -b flag the
use can request import of all bands (B0, B2, B3, MIR, and NDVI).
This changes the module API a bit as now the user points the module to the
metadata file (0001_LOG.TXT) and not to the NDVI file. I would be possible
to rewrite it so that the user can point to either of the two. Or just the
NDVI file... I'll get back to it when I find the time, unless someone else
wants to.
Priority: normal | Milestone: 7.0.7
I've just attached the patch provided by Tudor. It allows importing any
band, one by one. Probably more in line with the KISS principle than my
patch trying to loop over all files.
Priority: normal | Milestone: 7.8.0
Changes (by mlennert):
* milestone: 7.0.7 => 7.8.0
Comment:
I think this is still relevant, but am not a regular SPOT imagery user, so
am not 100% sure the patch is acceptable to all. Best bet is probably to
just apply it and see
