#3187: Attribute table manager refreshing when connecting a distant sqlite
database
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.0.6
Component: wxGUI | Version: svn-trunk
Keywords: database,layer | CPU: Unspecified
Platform: Linux |
Given a vector map without layer, you may want to make a connection with
an external database sqlite file. Doing this with the wxgui attribute
table manager, when specifying the path for an existing sqlite file,
'Table' and 'Key column' dropdown lists are not immediately refreshed, so
it is not possible to set properly the new layer. Update only happens if
you select another entry in the 'Driver' dropdown list (e.g. 'pg'), then
set it back to 'sqlite'.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3187>
