GDAL
1
#319: v.to.rast segfaults in G_close_gdal_link()
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: gdal_link | Platform: Linux
Cpu: x86-32 |
v.to.rast segfaults in G_close_gdal_link() when used with a FP
attribute column.
#spearfish
v.random out=rand1k_elev n=1000
v.db.addtable map=rand1k_elev column='elevation double precision'
v.what.rast vector=rand1k_elev raster=elevation.10m column=elevation
v.to.rast in=rand1k_elev out=rand1k.elev use=attr column=elevation
Converted areas: 0 of 0
Converted points/lines: 1000 of 1000
Segmentation fault
(gdb) bt full
#0 0xb7f165b2 in G_close_gdal_link (gdal=0x4091d861) at gdal.c:121
No locals.
#1 0xb7f09a20 in close_old (fd=6) at closecell.c:137
fcb = (struct fileinfo *) 0x808c650
i = 134516666
#2 0xb7f09928 in G_close_cell (fd=6) at closecell.c:86
#3 0x0804cc84 in update_labels (rast_name=0x8057d78 "rand1k.elev",
vector_map=0x8057d68 "rand1k_elev", field=1, label_column=0x0, use=1,
val=1, attr_column=0x8057d88 "elevation") at support.c:493
i = 0
fd = 6
Map = {format = 0, temporary = -1076280840, dblnk = 0x808fe38,
plus = {
output map looks ok on causal look.
presumably introduced with r.external changes.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/319>
GDAL
2
Resolution: | Keywords: gdal_link
Platform: Linux | Cpu: x86-32
Comment (by glynn):
Replying to [ticket:319 hamish]:
> attribute column.
Try merging r33690.
Ticket URL: <http://trac.osgeo.org/grass/ticket/319#comment:1>
GDAL
3
Comment (by neteler):
Already merged with r33693.
Please close if fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/319#comment:2>
GDAL
4
Type: defect | Status: closed
Resolution: fixed | Keywords: gdal_link
Changes (by hamish):
* status: new => closed
* resolution: => fixed
Comment:
works after svn up. Thanks.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/319#comment:3>
