[GRASS-dev] [GRASS GIS] #3191: coordinate reference system issue when exporting to Rasterlite
Reporter: vincent | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Raster | Version: unspecified
Keywords: gdal export, Rasterlite | CPU: Unspecified
Platform: Unspecified |
r.out.gdal allows to export raster data to Rasterlite tables. It looks
like the output raster table lacks a correct reference to the srid it
should be linked to, i.e. in the geometry_column table, srid equals -1 for
the newly written raster table.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191&gt;
Resolution: | Keywords: gdal export, Rasterlite
Comment (by hellik):
Replying to [ticket:3191 vincent]:
tested with
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r69714
Build date: 2016-10-24
Build platform: i386-w64-mingw32
GDAL: 2.1.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
with data (downloadable here [https://www.tirol.gv.at/data/datenkatalog
/geographie-und-planung/digitales-gelaendemodell-tirol/ data].
g.proj -p
-PROJ_INFO-------------------------------------------------
name : MGI / Austria GK Central
datum : hermannskogel
ellps : bessel
proj : tmerc
lat_0 : 0
lon_0 : 13.33333333333333
k : 1
x_0 : 0
y_0 : -5000000
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_EPSG-------------------------------------------------
epsg : 31255
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
projection: 99 (MGI / Austria GK Central)
zone: 0
datum: hermannskogel
ellipsoid: bessel
north: 230005
south: 159995
west: -96005
east: -23995
nsres: 10
ewres: 10
rows: 7001
cols: 7201
cells: 50414201
r.out.gdal input=lz_10m_float@user
output=J:\wd\checkraster\lz_10m\lz_10m\geotiff_out.tif format=GTiff
gdalinfo geotiff_out.tif
Driver: GTiff/GeoTIFF
Files: geotiff_out.tif
Size is 7201, 7001
Coordinate System is:
PROJCS["MGI / Austria GK Central",
     GEOGCS["bessel",
         DATUM["Militar_Geographische_Institute",
             SPHEROID["Bessel_1841",6377397.155,299.1528128],
             TOWGS84[577.326,90.129,463.919,5.1366,1.4742,5.297,2.4232]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",13.33333333333333],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",-5000000],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]]]
Origin = (-96005.000000000000000,230005.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
   AREA_OR_POINT=Area
   TIFFTAG_SOFTWARE=GRASS GIS 7.3.svn with GDAL 2.1.1
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -96005.000, 230005.000) ( 12d 3'57.90"E, 47d12' 8.96"N)
Lower Left ( -96005.000, 159995.000) ( 12d 4'50.98"E, 46d34'22.11"N)
Upper Right ( -23995.000, 230005.000) ( 13d 0'59.64"E, 47d12'32.62"N)
Lower Right ( -23995.000, 159995.000) ( 13d 1'12.91"E, 46d34'45.25"N)
Center ( -60000.000, 195000.000) ( 12d32'45.35"E, 46d53'30.77"N)
Band 1 Block=7201x1 Type=Float32, ColorInterp=Gray
   NoData Value=nan
gdal_translate -of Rasterlite geotiff_out.tif gdtrans_to_rasterlite.db
gdalinfo gdtrans_to_rasterlite.db
Driver: Rasterlite/Rasterlite
Files: gdtrans_to_rasterlite.db
Size is 7201, 7001
Coordinate System is `'
Metadata:
   TILE_FORMAT=GTiff
   INTERLEAVE=PIXEL
Corner Coordinates:
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
gdal_translate -a_srs EPSG:31255 -of Rasterlite geotiff_out.tif
gdtrans_to_rasterlite_srs.db
gdalinfo gdtrans_to_rasterlite_srs.db
Files: gdtrans_to_rasterlite_srs.db
Size is 7201, 7001
     GEOGCS["MGI",
             SPHEROID["Bessel 1841",6377397.155,299.1528128,
                 AUTHORITY["EPSG","7004"]],
             TOWGS84[577.326,90.129,463.919,5.137,1.474,5.297,2.4232],
             AUTHORITY["EPSG","6312"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AXIS["Latitude",NORTH],
         AXIS["Longitude",EAST],
         AUTHORITY["EPSG","4312"]],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AXIS["X",NORTH],
     AXIS["Y",EAST],
     AUTHORITY["EPSG","31255"]]
Metadata:
   TILE_FORMAT=GTiff
   INTERLEAVE=PIXEL
Corner Coordinates:
r.out.gdal input=lz_10m_float@user output=grass_to_rasterlite2.db
format=Rasterlite
gdalinfo grass_to_rasterlite2.db
Files: grass_to_rasterlite2.db
Size is 7201, 7001
Metadata:
   TILE_FORMAT=GTiff
   INTERLEAVE=PIXEL
Corner Coordinates:
testing with gdal_translate and r.out.gdal shows
- a simple gdal_translate from geotiff to rasterlite without assigning the
srs, the resulting rasterlite db has '''no''' srs info
- gdal_translate with e.g. -a_srs EPSG:your_epsg_code, the resulting
rasterlite db '''has''' srs info.
so it seems to be a gdal "issue"; maybe it's also worth to ask in the GDAL
ML?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:1&gt;
Comment (by vincent):
Yes, I've come to the same observation so far, but I don't know enough
about how GRASS parses projection info to gdal; sorry for this rather
naive question but in the case of GTiff driver why then is there no need
to worry about coordinate reference system information for it to work?
Well, if you all prefer, we can close the ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:2&gt;
Comment (by sbl):
Maybe related to: #3059[[BR]]
Symptoms are the same...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:3&gt;
Replying to [comment:2 vincent]:
taken from the [https://lists.osgeo.org/pipermail/gdal-
dev/2016-October/045359.html GDAL ML]
> is this intentional that there is no srs by a simple gdal_translate of a
> geotiff to a Rasterlite db?
From what I can see the driver doesn't handle adding a new entry in the
spatial_ref_sys table if there's no AUTHORITY node, such as in your use
case.
From what I can see, it also probably doesn't properly support creating
entries in spatial_ref_sys with Spatialite 4 layout (the driver has been
likely developped during Spatialite 3 era)
It is "intentional" in the meaning that this wasn't implemented, but could
potentially be added. Could be worth a ticket in Trac.
> maybe there is some other command line option related to Rasterlite db
> which I'm missing?
No, the workaround is the one you found. Make sure a EPSG code is attached
to
the input dataset, or assign it explictly
I think this ticket can be closed; but I'll open another one for the last
issue mentioned above.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:4&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: gdal export, Rasterlite
Changes (by hellik):
* status: new => closed
* resolution: => wontfix
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:5&gt;
Replying to [comment:4 hellik]:
last issue mentioned above.
ticket opened; see #3193
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:6&gt;
Replying to [comment:6 hellik]:
Not sure I understand: do you mean adding this "AUTHORITY node" ability to
r.out.gdal may help in the present case? or is there really something
wrong with gdal?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:7&gt;
Replying to [comment:7 vincent]:
to r.out.gdal may help in the present case? or is there really something
wrong with gdal?
regarding "AUTHORITY node", maybe yes.
as Even mentioned, there is nothing wrong in gdal, just not implemented.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:8&gt;
