[GRASS-dev] [GRASS GIS] #3207: Create histogram of raster map fails
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.2.1
Component: wxGUI | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: MSWindows 8 |
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r69793
Build date: 2016-11-10
Build platform: x86_64-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
   File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\ma
pdisp\frame.py", line 1158, in OnHistogramPyPlot
win = HistogramPlotFrame(parent=self, rasterList=raster)
   File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\wx
plot\histogram.py", line 45, in __init__
BasePlotFrame.__init__(self, parent, size=size, **kwargs)
plot\base.py", line 111, in __init__
self.client = plot.PlotCanvas(self)
NameError
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207&gt;
Resolution: | Keywords:
       CPU: x86-64 | Platform: MSWindows 8
Comment (by martinl):
Is this issue valid also for 7.2.0? (milestone set for 7.2.1)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:1&gt;
I cannot reproduce this bug (fresh 7.3svn on osgeo4w). Histogramming tool
is shown normally.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:2&gt;
Comment (by hellik):
Replying to [comment:2 martinl]:
tool is shown normally.
now tested with
System Info
GRASS version: 7.0.5
GRASS SVN Revision: 69636
Build Date: 2016-10-02
Build Platform: x86_64-w64-mingw32
GDAL/OGR: 2.1.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
   File "C:\OSGEO4~1\apps\grass\grass-7.0.5\gui\wxpython\mapd
isp\frame.py", line 1067, in OnHistogramPyPlot
win = HistogramPlotFrame(parent = self, rasterList = raster)
   File "C:\OSGEO4~1\apps\grass\grass-7.0.5\gui\wxpython\wxpl
ot\histogram.py", line 43, in __init__
BasePlotFrame.__init__(self, parent, size = size, **kwargs)
ot\base.py", line 92, in __init__
NameError
global name 'plot' is not defined
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:3&gt;
Replying to [comment:1 martinl]:
its here in OSGeo4W-GRASS version: 7.0.5 and OSGeo4W-GRASS version:
7.3.svn
so no idea which milestone to set. :wink:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:4&gt;
Comment (by annakrat):
I don't have any problems:
GRASS SVN revision: r69770
Build date: 2016-11-05
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Could other people test, too? That error should not really happen, is
there any other error before?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:5&gt;
Replying to [comment:5 annakrat]:
> GDAL: 2.1.2
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.14.1
> Python: 2.7.5
> wxPython: 2.8.12.1
In my tests I'm using OSGeo4W-winGRASS,as I can see, you are using the
standalone, right?
could it be the numpy issue that doesn't appear in standalone, but in the
OSGeo4W version?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:6&gt;
Replying to [comment:6 hellik]:
> > GDAL: 2.1.2
> > PROJ.4: 4.9.3
> > GEOS: 3.5.0
> > SQLite: 3.14.1
> > Python: 2.7.5
> > wxPython: 2.8.12.1
standalone, right?
the OSGeo4W version?
See #3057
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:7&gt;
standalone, right?
I cannot reproduce this issue even with osgeo4w installer. Could you
please test 7.2.0RC1 from experimental area? To know whether we need to
postpone RC2. Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:8&gt;
Replying to [comment:8 martinl]:
standalone, right?
see https://trac.osgeo.org/grass/ticket/3057#comment:18
standalone ''GRASS GIS 7.2.svn'' works without any problems; trying it
with the setup in #3057#comment:18 (standalone winGRASS pointing to the
OSGeo4W-python stuff), then I get the same error as reported above.
conclusion: the numpy startup issue (#3057) and this failing are
interconnected!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:9&gt;
standalone, right?
yes it's for me in the OSGeo4W-winGRASS 7.2.0RC1.
see further tests in #3057
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:10&gt;
The same as in #3094, fixed in r69797 in trunk, please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:11&gt;
Replying to [comment:11 annakrat]:
tested by
GRASS SVN revision: r69797
Build date: 2016-11-13
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
fix confirmed; closing ticket.
thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:13&gt;
      Type: defect | Status: reopened
* status: closed => reopened
* resolution: fixed =>
Comment:
reopen, as backport needed (?).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:14&gt;
  Priority: blocker | Milestone: 7.2.0
Changes (by martinl):
* priority: critical => blocker
* milestone: 7.2.1 => 7.2.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:15&gt;
Changes (by annakrat):
* status: reopened => closed
Comment:
Backported to 72 and 70.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:16&gt;
