[GRASS-dev] [GRASS GIS] #3212: r.in.wms crashes if server does not exist
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-releasebranch72
Keywords: r.in.wms | CPU: Unspecified
Platform: Unspecified |
Since free WMS services come and go, the script should not crash if a OWS
server does not exist (likely "easy" to try/except):
Here a test case:
nslookup bla.bla/ms
** server can't find bla.bla/ms: NXDOMAIN
# using script with non-existing WMS server:
r.in.wms -c url="http://bla.bla/ms"
   File "/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-
gnu/scripts/r.in.wms", line 236, in <module>
     sys.exit(main())
gnu/scripts/r.in.wms", line 218, in main
     wms.GetCapabilities(options)
gnu/etc/r.in.wms/wms_base.py", line 275, in GetCapabilities
     cap = self._fetchCapabilities(options)
gnu/etc/r.in.wms/wms_base.py", line 252, in _fetchCapabilities
     msg += _("\nReason: ") + e.reason
TypeError: cannot concatenate 'str' and 'gaierror' objects
A "Server not found" message would be appreciated in such case.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3212&gt;
Resolution: | Keywords: r.in.wms
Comment (by martinl):
In [changeset:"69848" 69848]:
#!CommitTicketReference repository="" revision="69848"
r.in.wms crashes if server does not exist (see #3212)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3212#comment:1&gt;
In [changeset:"69849" 69849]:
#!CommitTicketReference repository="" revision="69849"
r.in.wms crashes if server does not exist (relbr72 merge 69848 from trunk,
see #3212)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3212#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.in.wms
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"69850" 69850]:
#!CommitTicketReference repository="" revision="69850"
fix #3212)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3212#comment:3&gt;
Fixed in all active branches, `r.in.wms` reports
ERROR: Unable to fetch capabilities from <http://bla.bla/ms&gt;\. Reason:
[Errno -2] Name or service not known
Ticket URL: <https://trac.osgeo.org/grass/ticket/3212#comment:4&gt;
